March 6, 2015, 08:28 |
cartesian velocity components?
Hydreaulic structures
Rep Power: 14 |
hi every body
i used ansys version 14, in fluid settings tab in cartesian velocity components, u,v,w On what basis spicified? i using free surface and cartesian system and i have two phase consist of water & air, i have depth and velocity in inlet from experimental data, but i dont know exact velocity components, whether I can put it on automatic setting and What is your suggestion? please help me thanks a lot |
March 6, 2015, 20:02 |
Rep Power: 144 |
You have to apply boundary conditions at locations where you know the flow conditions. If you do not know the flow conditions then you cannot apply boundary conditions.
But can't you guess that the flow direction is normal to the boundary? This is the normal approach. |
March 7, 2015, 02:09 |
Rep Power: 14 |
hi dear glenn
If my guess with the actual values have big difference, How much effected on my results? Do you think if I put it on automatic setting Is not better? slope of chutes is 17 degree, horizontial length is :53 m, velocity inlet is:25m/s , depth inlet :1 m please tell me your opinion, thanks a lot for help me |
March 8, 2015, 04:31 |
#4 | ||
Rep Power: 144 |
My opinion of the model you show is that you are unlikely to get that to converge as the down stream boundary is likely to be in the region where the flow is still recovering from the hump. You are going to have to move the downstream boundary further downstream. If you know the depth and velocity at the inlet it should be OK. |
March 9, 2015, 13:54 |
Rep Power: 14 |
dear glenn
thanks a lot for spending time for me, my mean of settings is two method that i can considered, As you know cartesian velocity components is Adjustable in 2 modes are automatic with value & automatic, my mean is when i dont know exat value of u , v ,w , is not better i using automatic. i have normal speed & velocity in inlet thanks a lot dear glenn. |
March 9, 2015, 16:16 |
Rep Power: 144 |
Automatic with value uses an initial condition if one is provided, otherwise the specified value. Automatic just uses an initial condition if one is provided, otherwise the global initial condition.
If this is for an initial condition then you can often use a guess as the flow will generate the flow soon enough. |
March 13, 2015, 12:25 |
Rep Power: 14 |
dear glenn, thanks a lot for help me
Individual convergence criteria for velocity components? | CoolHand | OpenFOAM Running, Solving & CFD | 0 | March 3, 2014 16:47 |
foamToVTK and velocity components. | Luchini | OpenFOAM Post-Processing | 0 | February 6, 2014 12:07 |
Calculate velocity components from shear stress | Arnoldinho | OpenFOAM Running, Solving & CFD | 0 | August 29, 2011 12:07 |
components of velocity used by fluent and cfx | Ardalan | Main CFD Forum | 1 | March 7, 2010 21:25 |
Cylindrical velocity components | Kshitij | FLUENT | 1 | February 10, 2006 03:58 |
