March 4, 2015, 12:48 |
Thermal analysis - heat capacity
Roland Rakos
Rep Power: 17 |
I have a transient thermal simulation including fluid and solid domains. If I reduce the specific heat capacity value in the solid domain than what will be the difference? I expect that the reduced heat capacity in solid will result the same final temperature distribution and values in solid domain but the time of temp. changing will reduce. Please confirme me if this is true. Thanks Roland |
March 4, 2015, 14:16 |
Erik
Rep Power: 23 |
Yes, in steady state specific heat in solid domain doesn't matter. But In transient you will get the wrong solution on both domains. I'm not sure why you would want to do this?
March 5, 2015, 12:59 |
#3 | |
Roland Rakos
Rep Power: 17 |
I have a model which inlcudes a transient temperature/pressure boundary conditions. The T and p change periodically at the inlet as a result I have to calculate it as transient case. The averaged T and p (instead of the sinus signal) are wrong solution because the periodic mass flow (and velocity) is also important boundary condition... My main problem is that the time step of fluid domain has to be very small because the frequency of sinus signal is high, about 50Hz but the temperature will increase in the solid very very slowly... I would like to reach a special solution where the temp. of solid can increase very fast... Do you understand my problem? regards Roland |
March 5, 2015, 17:26 |
Rep Power: 144 |
Your problem is a typical one for CFD - different parts of the simulation have vastly different time scales, so you need a fine time scale to resolve the small time scale, but run it forever to resolve the large time scale.
If you are running this steady state you can use acceleration factors to even things out and achieve convergence quicker, but in transient you have to be clever. In a transient simulation your options include: * Simulate the fast time scale and get its output to the long time scale (in your case heat to the solid). Then do a simulation of the long time scale thing using the heat input. So you split the simulation into a fast and slow one. * Replace the transient input (temp/pressure) and replace it with a weighted average. Then do a steady state simulation on the long time scale. * Simulate the fast time scale to get the heat. Then use a simple ODE solver to get the temperature of the solid over time. Which approach is best will depend on your exact requirements. But the basic idea is you split the simulation into a fast and a slow time scale one, and link them with the physical parameter which links the time scales. |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 05:28 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
