March 3, 2015, 09:22 |
duct bocos
High guys,I am studying a curved 3D duct that has a staight part in the end. The pressure in the exit of the straight part is atmospheric but I want to define another measured static pressure right after the curved part of the duct and before the straight part. How can I do this? I tried with an extra surface, which i defined as outlet but I had the "isolated fluid regions" problem. Any suggestions??
Thanks |
March 3, 2015, 18:39 |
Rep Power: 144 |
It sounds like you want to define a boundary condition in the middle of the domain and this does not sound like a good idea. If you know the flow at either end of the straight pipe then why model the curved pipe at all? If you need the flow profile from upstream then do a model of the curved pipe as one model then use a profile boundary condition on the straight pipe for a straight pipe simulation.
Fabric Duct Modeling | Dan | FLUENT | 1 | September 27, 2024 04:43 |
analyzing the temperature of fliud (air) flow inside an underground duct. | arshbunny | CFX | 9 | April 3, 2014 09:52 |
Total pressure increase in the diverging duct | shiv | Siemens | 3 | February 1, 2008 04:39 |
modelling fuel cell duct in fluent | rajesh kumar tippabhotla | FLUENT | 2 | October 7, 2004 13:04 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
