Absolute Pressure not equil to Pressure + Ref. Pressure, why? |
March 3, 2015, 06:27 |
Arkadiy
Rep Power: 11 |
As i understood, Absolute Pressure can be computed as sum of Pressure and ref. Pressure, but in my case CFX acts in different way, and should know that way! Please help!!
I attached pics from my case, ref. Pressure = 5,5 [atm] |
March 3, 2015, 08:51 |
Rep Power: 33 |
By any chance, did you activate the buoyancy model ? You may be seeing the hydrostatic pressure contribution as well.
March 3, 2015, 09:39 |
Arkadiy
Rep Power: 11 |
Buoyancy model is activated and i tried to account it by creating an expression (Pressure+Density*g*Y+Reference Pressure), but at the and, i didn't get values equal to Absolute Pressure
So how i can get values of Absolute Pressure using Pressure? Last edited by Arkadiy Kr; March 4, 2015 at 06:36. |
March 4, 2015, 06:33 |
#4 | |
Arkadiy
Rep Power: 11 |
But i'm still confused about Pressure Drop. I can not use Pressure difference between top and bottom levels, as I get negative values which is not physically possible and I can not use Absolute Pressure difference between top and bottom levels, as Hydrostatic Pressure assumes that domain is filled by only one fluid, but it's not. |
March 4, 2015, 12:07 |
Rep Power: 33 |
If your calculation of the hydrostatic pressure assumes anything about the number of fluids, it is incorrect.
Have you tried computing the hydrostatic pressure as (Fluid 1.Volume Fraction * Fluid 1.Density + Fluid 2.Volume Fraction * Fluid 2.Density ) * ( g . (position vector - reference location) ) That should account for the weight of the column of fluid. Notice the . to account for any possible orientation as well as the reference location (which I assume you provided to the software) |
March 5, 2015, 09:29 |
#6 | ||
Arkadiy
Rep Power: 11 |
balance between pressures, pressure area |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Negative absolute pressure | Turbulent | CFX | 13 | September 8, 2015 20:54 |
why absolute pressure and temperature limited to 1.000000e+00? | wildli | FLUENT | 1 | January 28, 2010 02:25 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
