How can i assign a set of data (table or matrix) as an input for source term?
Old   March 2, 2015, 07:07
Default How can i assign a set of data (table or matrix) as an input for source term?
reza.s is on a distinguished road
Hi
I am simulating a channel flow in cfx and i need to add source term to continuity equation.in order to add mass source term i need to set its temperature.instead of assigning a constant temperature value for whole domain, i want to use a set of temperature values (like a temerature matrix) over my domain. my question is:
is it possible in cfx to assign a set of data as an input instead of a fix value or an expression? How can i do it?
I am new to cfx so please help me.
thanks in advance.
reza.s is offline   Reply With Quote
Old   March 2, 2015, 09:48
Edmund Singer P.E.
singer1812 is on a distinguished road
Look up tables or functions. These are pretty easy to use, and you can even import a file with the values you want to use.
If you have further questions after reading up, please ask.
singer1812 is offline   Reply With Quote
Old   March 2, 2015, 10:59
thanks singer1812 for taking your time and answering my question. I did as you said and looked up cfx document under user functions. as you said ,I can create a set of data including coordinates and quantity of interest and cfx will use interpolation to calculate values on nodes.
you said i can import file containing values i want, is it possible to use results of another cfx simulation (in the same geometry ) to generate such a file that can be used as input like you said?
thanks again.
Old   March 2, 2015, 12:12
Opaque will become famous soon enough
If the results you require from a previous simulation can be associated to a post-processing locator such as a boundary, surface group, etc, you can use the export functionality in CFD-Post.
Select the BC export profile, customize it for the type of export you require and the .csv file written can be then imported into CFX-Pre.
You may need to read the CEL syntax details on how to hook up such .csv file.
Opaque is offline   Reply With Quote
Old   March 2, 2015, 19:25
thanks opaque for your reply.
what i want is not boundary condition. to add mass source term, I need to specify temperature for this added mass as an input. I want to use temperature field from a previous simulation as temperature required in mass source term tab in cfx .
Is it possible to this in cfx using the export functionality in CFD-Post that you mentioned?
thanks a lot.
Old   March 2, 2015, 21:31
It will export as you need. However, the file may be large and I am not sure about the performance of the software dealing with it.
I would try it in a coarse mesh first, and see if it work as you desire, and then go for the final mesh.
cfx, input value, source term
Set a Source/Sink Term into a approriate cell QuocHung_Phan FLUENT 0 November 24, 2012 09:05
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
mykEpsilon - How to set a min/max constraint for a term with units elektra79 OpenFOAM 3 October 12, 2010 19:12
Plasma Flow Modelling using Source term and cell's data Constantine Fluent UDF and Scheme Programming 2 May 19, 2010 22:06
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
