Axial Flow between rotating cylinders
Old   February 28, 2015, 07:01
Default Axial Flow between rotating cylinders
Dynampally Pavitran
pavitran is on a distinguished road
I have a query regarding axial flow (turbulent) between rotating cylinders (Same angular speed). Please see the attached image. The radius of the inner cylinder is 200 mm (please see the attached image) and the outer cylinder radius is 300mm and the flow is parallel to the axis of rotation. My queries are:
1. Should I consider the computational domain as stationary and inner & outer cylinder as rotating wall?
2. Or should I consider the entire computational domain as rotating domain?
pavitran is offline   Reply With Quote
Old   February 28, 2015, 07:36
You should use a stationary domain and the walls as a rotational tangential velocity.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Rotating flow nasir.iitd FLUENT 4 July 8, 2014 11:37
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 05:40
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
