non zero exit code 2
Old   February 25, 2015, 00:41
Default non zero exit code 2
ashwani
ashwani.thakur is on a distinguished road
i m using 8gb ram, i7 processor
i m doing problem of cfd of a steam turbine blade in ansys cfx
i m getting the following error:
Details of error:-
Error detected by routine MAKDAT
Illegal data area length CDANAM = NTOTALS_EST CDTYPE = INTR ISIZE = 0
CRESLT = SIZE
Current Directory : /INTERP/NEW/NAMEMAP
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: C:\Program |
| Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\solver-pcmpi.exe exited |
| with return code 1.
ashwani.thakur is offline   Reply With Quote
Old   February 25, 2015, 00:49
ashwani
please help as it is my thesis work and i have to submit it soon
is it somethinf to do with geometry or mesh, or boundary conditionf
i have used serial solver with 3 partitions
Old   February 25, 2015, 01:46
ashwani
also the same problem is working fine when i m using a box domain instead of a curved domain for blade
can there be a problem in inlet flow direction of steam defined by me
Old   February 25, 2015, 06:26
There is some sort of problem with the interpolation of an initial condition onto your simulation. You have not provided any details of what you are doing so I cannot say anything more than that. I do strongly recommend you have a look at the tutorial examples. A few of them use initial condition interpolation I think. That is the best place to sort out basic problems like this.
ghorrocks is online now   Reply With Quote
Old   February 26, 2015, 01:50
ashwani
i m doing the problem on steam flow across a rotor blade
i reduced the no. of nodes and elements and the problem worked fine but it showing following message during solving:
****** Notice ****** |
| A wall has been placed at portion(s) of an INLET |
| boundary condition (at 1.6% of the faces, 1.5% of the area) |
| to prevent fluid from flowing out of the domain. |
| The boundary condition name is: inlet. |
| The fluid name is: Fluid 1. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. |
| A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 10.7% of the faces, 11.1% of the area) |
| to prevent fluid from flowing into the domain. |
| The boundary condition name is: outlet. |
what does it mean and can it affect my results to use opening instead of inlet and outlet conditions.
Old   February 26, 2015, 05:17
FAQ: http://www.cfd-online.com/Wiki/Ansys...f_an_OUTLET.22
Old   February 27, 2015, 11:30
ashwani
thanks for reply
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 05:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 12:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
