February 23, 2015, 16:47 |
Pipe Flow-Inlet temperature profile
Dear Friends,
I am doing LES of T-junction mixing flows. Hot fluid (in main pipe) is at 142 °C with 0.11 m/s velocity. Cold fluid (in branch pipe) is at 25 °C, flows at 0.08 m/s. I have two questions with regard to my inflow boundary condition at hot pipe: - Hot fluid flow is thermally stratified (about 14 °C between top and bottom of pipe) as seen from experimental data. Any suggestions on computationally incorporating this phenomenon into inflow boundary condition? I have temperature data at four angular positions (top, bottom,left and right). - This is a follow up to the question above: Just as inflow velocity profile for developed flows, is there a defined inflow temperature profile (from top to bottom of pipe's cross-section)? It would be helpful if any references to literature are cited to learn about this topic. Thank you for the help. Regards, Karthick |
February 24, 2015, 02:01 |
Rep Power: 144 |
You can use a inlet profile for the thermal stratification, or define a CEL expression as a function of some dimension as two easy options.
Any question about thermal model should go straight to the seminal textbook on the are (well, at least the seminal textbook for me): Heat and Mass Trasfer by Incropera and DeWitt. |
February 26, 2015, 11:52 |
Pipe inflow temperature profile
Dear Glenn,
Thank you for recommending Heat and Mass Transfer text book. It really has some very basic information that is very useful to me. Regards, Karthick |
boundary condition, temperature profile, turbulent flow |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Periodic Pipe Flow LES; parabolic profile | jrrelx | FLUENT | 34 | August 13, 2015 18:58 |
Strange velocity profile at the inlet for a flow inside a cylindrical pipe | michmich | OpenFOAM Running, Solving & CFD | 0 | July 2, 2012 04:37 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 11:14 |
LES of highly heated pipe flow - incorrect results | MichalH | FLUENT | 3 | June 3, 2009 06:00 |
