February 18, 2015, 11:46 |
CFX Distributed Parallel Setup
Pavel
Rep Power: 12 |
Hiya,
I want to link 2 PC + 1 Laptop to run CFX using the MPI Distributed parallel processing option. Could I get some help on how to physically connect the computers? Here are the specs:
I run simulations to model the turbulence on the seabed for offshore cables. Thanks very much for your help! |
February 18, 2015, 18:35 |
Rep Power: 144 |
The instructions to get network parallel working are all in the ANSYS installation guide.
But as a general comment: network parallel works best with similar computers. When you use a range of computers you tend to get a far poorer speed up. You can offset this marginally by biasing the partition size to offset the computer speed but it usually you cannot completely fix it. This results in a parallel simulation which is only marginally faster (or slower) than simply doing it serial or with a smaller network. |
cfx, distributed, parallel computing |
Remote cluster parallel solve without master, Ansys CFX 14.5 | aaguirre | CFX | 4 | January 27, 2015 10:15 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 20:05 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 07:17 |
Distributed Parallel on dual core remote machine | Justin | CFX | 1 | February 3, 2008 18:23 |
PVM RSH parallel setup problem Windows XP | abe | CFX | 11 | January 30, 2006 06:10 |
