February 17, 2015, 14:25 |
Multiple time points in CFX-Post chart
NC
Rep Power: 11 |
How can I make a chart that multiple lines, each represent a definite time point in the transient solution? For example, imagine a velocity profiles at different times.
What I have currently is one line, which changes according to the time point I choose using the selector. Thanks. |
February 17, 2015, 15:41 |
Edmund Singer P.E.
Rep Power: 21 |
Try creating a new variable (frozen copy) of the variable you want to plot. Do this at each time point. Plot each variable on the same chart.
February 18, 2015, 03:49 |
Thomas MADELEINE
Rep Power: 12 |
If you want a chart with multiple variable that are not available in the same time the easiest way from my point of view is to use excel...
you can easily export the data of your chart and then create one sheet on excel to plot all together... |
February 19, 2015, 11:12 |
NC
Rep Power: 11 |
Thanks, Thomas. That worked.
cfx-post, chart |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
CFX Post: Problems with moving point cloud for changing time steps | spatialtime | CFX | 0 | December 7, 2009 04:56 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
