Compressor Surge Analysis- CFX
Old   February 16, 2015, 08:58
Question Compressor Surge Analysis- CFX
Prakhar
Prak_32 is on a distinguished road
I am working on comparing the surge behavior of a compressor with some design modifications. I am using a single blade passage for the same.
I have my simulations running, but I need to compare the surge behavior of the same. How can I do that ?
I read in a few papers to monitor the pressure fluctuations at a boundary and these variations can give an indication of stability. How can I do this?
Or is there any other method I can use?
Looking forward to replies
Regards
Prakhar
Prak_32 is offline   Reply With Quote
Old   February 16, 2015, 17:29
Have you read the best practices guide in the CFX Reference manual? It gives lots of information about these sort of models.
Old   February 17, 2015, 05:15
Prakhar
Dear Glenn,
Yes I have read the best practice guide, I agree it gives a lot of insight but unfortunately I could not find my answer there.
I am simulating two centrifugal compressor design's and need to compare their surge behavior ( low mass flow rate stability). I read some papers on the same which said to monitor or plot the pressure variation at a boundary. Comparison between the amplitude of oscillations can indicate the marginal stability of performance. Is this correct?? If yes how can I monitor the pressure?
Is there any other method to predict/ monitor the compressor surge?
Regards
Prakhar
Old   February 17, 2015, 18:07
I am not an expert on compressor design. If you have quality research papers which describe a method as you describe then that sounds like a good thing to try.
Old   February 18, 2015, 04:53
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
If the paper is available online, can you send a link to it please ?
I am very interested about it
Thomas MADELEINE is offline   Reply With Quote
cfx, compressor, stability analysis, surge
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 wan11 CFX 3 December 18, 2014 20:25
Flow Analysis tilting Pad thrust bearing using CFX julien CFX 5 April 9, 2014 09:38
How to Check Mass Flow Rate in 2D Analysis - CFX nasir FLUENT 0 October 9, 2011 03:52
CFX and acoustic analysis mahdinili CFX 2 September 21, 2011 17:16
CFX 2D ANALYSIS BOUNDARY CONDITION fat bug CFX 1 February 19, 2008 17:22
