Continuous streamlines across non-conformal interfaces - CFX
Old   February 13, 2015, 08:49
Default Continuous streamlines across non-conformal interfaces - CFX
francois
francois louw is on a distinguished road
Hi all
I'm modelling a fan and my domain consists of various sub-domains 'stitched' together. Where the sub-domains meet, the interfaces are non-conformal. The entire domain is solved in the rotating reference frame. Therefore every sub-domain is static relative to the other.
I'm presently having trouble trying to plot continuous 2D streamlines on a surface through my domain in CFX. I've read all the posts on "Velocity in stn frame" and the relative "Velocity" options in CFX, but I think my problem is a little different since I do not have an MRF between my "rotor" sub-domain and the rest of the computational domain. I'm plotting the "Velocity in stn frame", but a discontinuity still occurs at the interfaces (see figure attached). Is it possible that CFX can plot continuous streamlines in this case.
Any help would be appreciated.
Kind regards
Francois
File Type: jpg B fan g15 me4r ker m1 v5_t01_glob_streamlines1.jpg (66.1 KB, 172 views)
francois louw is offline   Reply With Quote
Old   February 13, 2015, 19:33
I think there is an option to plot streamlines over periodic boundaries. I would select that.
Also, make the streamlines go forwards and backwards.
What are you using as the seed points for the streamlines?
ghorrocks is online now   Reply With Quote
Old   February 16, 2015, 04:36
francois
Hello Glenn
First of all, thank you for your faithful replies as always.
Following on the topic in question:
The streamlines are now plotted with the "forward and backward" option enabled. The option for "cross periodic boundaries" is only available for 3D streamlines and not surface streamlines. If I however switch to 3D streamlines, the streamlines are continuous, but this is not what I want. (I would like to see the surface streamlines in the meridional plane and preferably continuous across the interfaces.) Do you think a possible reason might be the fact that the simulation was solved in Fluent and only post-processed in CFX post?
The periodic boundaries of my domain are also non-conformal, since it is an unstructured poly-mesh and therefore had to be solved by means of a periodic interface (where interpolation occurs between the selected periodic boundaries).
I've tried all the seeding options available in CFX (e.g. "vertices", "rectangular grid", etc.), but still do not find the streamlines to continuously cross interfaces. I've also tried the help manual, but have not found answers yet.
Regards
Francois
Old   February 16, 2015, 05:22
No the solver used should not matter in this issue.
I understand why the streamlines are discontinuous across domains - and if you are extracting a meridonal plane then this is going to be tricky to fix.
As a wild guess have you tried generating your meridonal plane using a user surface rather than a plane? I suspect it won't work but it might work and it should be easy to do so it is worth a try.
The best thing I can recommend is to use the line generated on the boundary of the domain as a seed for the streamlines, then do forward and backward streamlines. This will make some streamlines continuous across the interface but not all.
Another idea is to draw shorter streamlines (maybe limit them to 1s of flow time or what ever a sensible time is). Then the discontinuity at the interface will not be so visible.
cfx, discontinuous, streamline
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 09:00
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
CFX 4 for two continuous fluid flow solution sinjae CFX 1 May 19, 2001 04:07
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
