boundary Control Problem
Old   February 2, 2015, 06:13
Default boundary Control Problem
tom hanks
iman512003 is on a distinguished road
I have a question regarding the boundary control problem. In general, I need to access the fluid parameters such as pressure and velocity and perform some sort of calculation on them, for instance I need to integrate the function J_a(P) on the inlet, J_a is the Bessel function of the first kind and ''P'' is the pressure at the inlet, is it possible to perform such an integration on the boundary using CFX user fortran? If yes could you please help me with some hints. If not, is it possible to do this in Fluent?
iman512003 is offline   Reply With Quote
Old   February 2, 2015, 17:48
Yes, it should be possible to do this. Have a look at the user fortran examples in CFX. ANSYS support also has some user fortran examples you should have a look at.
boundary control, cfx, user fortran
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
