April 23, 2015, 00:00 |
#21 |
Rep Power: 144 |
There are several problems with the mesh you show:
* I assume you want to model the river with a free surface. In that case you need to mesh a region of air above the river level as well. * You do not mesh the impeller. This is such a common mistake recently that it would be good if somebody wrote an FAQ about it. * You model the fluid region around the impeller with the impeller as a cut out region inside the domain. have a look at how the rotating machinery is modelled in the tutorials. * You put the domain around the impeller in a cylindrical domain and set it to be a rotating frame of reference, and connect this domain to the surroundings with a GGI interface |
April 24, 2015, 03:57 |
#22 |
Miss Anna
Rep Power: 11 |
Thank you very much for your comment.
I have made new setup for this simulation by considering your comment. But, this time i use boolean operation to eliminate the water wheel structure. Besides that, I have include the air domain in the analysis to take account the air region in the river. Is it correct if I just eliminate the water wheel just like the picture attached. How can I apply the rotating frame of reference here? |
April 24, 2015, 06:50 |
#23 |
Rep Power: 144 |
As a rotating frame of reference domain should be cylindrical, you will need to put the impeller in a cylindrical cut out region. You then connect the stationary outer domain to the cylindrical inner domain with a GGI with a frame change condition.
April 26, 2015, 13:59 |
#24 |
Miss Anna
Rep Power: 11 |
Thank you very much for your reply.
Oh I see. So, I have to make a rotating domain in the form of cylindrical right? I have improved my setup based on your comment. But, when I runned the simulation, it produced no result. I have keep searching where the possible cause of the error. But, I still have no idea why it happened. Do you have any idea of this problem? Thank you. |
April 26, 2015, 20:35 |
#25 |
Rep Power: 144 |
The error message is very clear - it failed to interpolate an initial condition onto this mesh.
June 8, 2016, 00:24 |
Simulation of rotating undershot waterwheel
#26 |
Ana Fadilah
Hi Everyone.
I am also working on simulation of water wheel in open channel flow. I am using Ansys CFX and using multiphase model which includes water and air as the working fluid. I setting different inlet for both fluid. For water inlet, I set the velocity 0.03 m/s while for air inlet, I set the velocity to 0 m/s. For outlet, I set the BC to static pressure with 0 relative pressure. I attached the figure of my result here. I am confusing why the water volume fraction is becoming like this. I dont have idea why the flow of water are becoming like this especially at the outlet. And, Is it possible for the torque to be negative? Thank you. Best regards. |
ansys cfx14, water wheel |
Water wheel simulation | Ema40 | FLUENT | 4 | November 13, 2014 03:35 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | ANSYS | 0 | September 16, 2014 02:06 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | CFX | 1 | September 15, 2014 08:40 |
Simulation of tiltable bucket with water | jurij | CFX | 2 | August 21, 2012 21:49 |
Vehicle Simulation with Rotating Wheels | Natalia Castro Naranjo | FLUENT | 1 | May 14, 2012 11:39 |
