Incomplete velocity profile import
Old   January 25, 2015, 18:16
Default Incomplete velocity profile import
MissCFD is on a distinguished road
In CFX, I would like if I import a velocity profil which is incomplete near wall as initial conditions, is the software will complete automatically with linear and log laws ?
Thank you for your help
MissCFD is offline   Reply With Quote
Old   January 26, 2015, 07:33
awesim is on a distinguished road
Hello MissCFD,
when defining the velocity profile as a user function you can check boxes to extend the minimum and maximum values. As far as I know it will just take the last value for every subsequent location until reaching the next bound (probably a wall). So make sure the values closest to the walls are no outliers.
Hope that helps,
Simon
awesim is offline   Reply With Quote
Old   February 22, 2015, 20:55
Thank your for your answer Simon.
I have an another question in the same way. If i import a velocity profile as a user function, is the cells size of my mesh must be less or greater than distance between two points of my velocity profile ? I tend to say that it's "less".
Thank you for your help again.
Originally Posted by awesim View Post
Hello MissCFD,
Hope that helps,
Simon
Old   February 23, 2015, 05:24
In terms of stability for your simulation it shouldn't really matter how many sampling points you choose for your profile or what distance there is between your nodes, respectively. But it will affect the precision of your inlet boundary flow since the actual values at the nodes of your grid will be interpolated from the given profile. So most accurate would be to have a profile which points are already located on the nodes of your inlet boundary. But in most cases that's not really necessary.
Old   February 23, 2015, 12:32
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
From what I understood of importing BC :
with basic options, when you import a profile CFX create a function (RxRxR -> R) so at each point in space it has a value for your variable (velocity).
Since you have only some point (from your mesh), CFX interpolate it to a continuous function (with a basic linear mode between two points). After that when you use the function for your BC it just match the point of your current mesh with the function.
I think you can use some option for the function to use a logarithmic law to interpolate the function.
Thomas MADELEINE is offline   Reply With Quote
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 09:09
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
