Mixing Efficiency of Static Mixer
Old   January 12, 2015, 21:26
Default Mixing Efficiency of Static Mixer
wesley.wavershak is on a distinguished road
I've modeled and meshed a simple static mixer and I want to find the efficiency in which it mixes two fluids of equal properties. Diffusion will take a very small role in the mixing; I'd be using viscous fluids in an attempt to model the mixer geometry's effectiveness at optimizing advection. My initial thoughts were to somehow inject a tracer at the inlet of the mixer, and measure the concentration of the tracer at the end of the mixing element, similar to what is shown in the video below. However, I'm only concerned with the overall performance rather than visualizing the process.
https://www.youtube.com/watch?v=Pr_QiQADlMM
Ultimately, I'd want to create a cascade of these mixing elements and measure the mass fraction at the end of each element.
I have very little experience in CFDs, and the complexity of the program is daunting and I'm not even sure where to begin.
wesley.wavershak is offline   Reply With Quote
Old   January 18, 2015, 06:49
Do the tutorials. Solve some benchmark simulations and compare against reliable results. After you can accurately solve benchmark simulations similar to the real problem you wish to simulate only then start your actual simulations on the real problem.
Old   February 6, 2016, 19:32
pmechz is on a distinguished road
hi every body.How Can I define a complicated relation like this in fluent:
a^2=(1/n)*sum(Ci-C)^2
where C is the mean value of the concentration field and Ci is the concentration for ith cell in the cross sectional area of outlet, n is the number of grid points in outlet
pmechz is offline   Reply With Quote
Old   February 6, 2016, 21:32
Try the fluent forum.
Old   February 7, 2016, 07:09
what do you mean?I'm a biginer here
I mean I couldnt find it
Old   February 7, 2016, 07:28
http://www.cfd-online.com/Forums/fluent/
Old   February 7, 2016, 08:01
Originally Posted by ghorrocks View Post
thanx for your reply
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
Simulating a static mixer in Fluent Novice FLUENT 1 January 26, 2009 14:09
