CEL Code for Sinusoidal Movement of Piston
Old   May 6, 2015, 20:14
For a 3D region you need to define it in your mesh. So you will need to set this up in the meshing software.
Old   May 22, 2015, 10:30
Dr Gurubasavaraju
gbrajtm is on a distinguished road
Hi sir,
I considered 3D region, But i am getting an negative volume element. I tried by changing the mesh size, but i am not able to get rid of the error(attached). Can you please suggest some remedy.
gbrajtm is offline   Reply With Quote
Old   May 23, 2015, 07:18
FAQ: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F
Old   July 4, 2015, 03:30
Dr Gurubasavaraju
Hello sir,
Greetings, Hope your are doing great.
After trying many iteration to resolve negative element implementing CEL, now i am getting some results (force vs displacement) need to verify them with experimental results after the completion of test. Hope it will have agreement.
Thank you very much for your kind help.
I will contact you if i get any trouble forth.
Kind Regard's
Guru
Old   July 10, 2015, 09:29
Dr Gurubasavaraju
Hello sir,
i wanted to give a boundary condition for bottom of the piston, which is diaphragm with certain elastic constants. Presently i have given wall boundary condition. I searched for elastic boundary condition.
Could you please suggest some remedy, if there is any possibility of modelling it.
Old   July 11, 2015, 07:06
Elastic constants? You mean the piston has a diaphragm which deforms? Then this is an FSI simulation, or possibly a moving mesh with the motion prescribed by the force on the diaphragm.
Old   July 13, 2015, 02:50
Dr Gurubasavaraju
Sorry, its not diaphragm, its accumulator with certain pressure.
please find the image.
Old   July 13, 2015, 08:55
If the accumulator piston has no inertia then you can model its motion using CEL expressions in CFX. If the accumulator has inertia you will need to use a rigid body solver.
Old   July 13, 2015, 09:01
Dr Gurubasavaraju
yes, but the pressure acting on the accumulator opposite to piston, how can that be specified?
Old   July 13, 2015, 09:09
If there is no interia then the piston will move such that the fluid force equals the accumulator pressure force. So the piston location is an algebraic function of the fluid pressure, and you do not need to model the piston or accumulator directly at all.
Old   July 13, 2015, 10:45
Dr Gurubasavaraju
i am sorry sir, I didn't understand, "piston location is an algebraic function of the fluid pressure"
Old   July 13, 2015, 19:53
It means the Piston location = f(known variables). It is not an ODE or PDE or implicit function.
Old   January 7, 2016, 06:23
Dr Gurubasavaraju
CFD.PNGDear sir,
As in attached, I have used solid body as the rigid body. Here i need to specify the two region in an if condition to distinguish Newtonian and Non Newtonian.
Since there are two non newtonian region i am not able to specify it in one if condition. How to specify it?
Previously i used this for one Non Newtonian region.
if(inside@piston == 1,a, 0.11 [kg m^-1 s^-1])
Old   January 7, 2016, 19:45
In future please start a new thread for a new question.
The easiest way of doing this is as you have done, by making the material properties a function as you have done. Note that this is quite likely to lead to convergence problems as you might get a step change in material properties.
If you are modelling a fluid where it has non-Newtonian behaviour near the piston and Newtonian behaviour away from the piston as the fluid is shear dependant (or something like that) - then I would not use any special model for this at all. Model the entire fluid region with the same non-Newtonian model and it will naturally revert to Newtonian behaviour away from the piston as the shear rate is low.
Old   January 8, 2016, 02:05
Dr Gurubasavaraju
ok sir,
http://www.cfd-online.com/Forums/new...=newthread&f=4
Old   January 8, 2016, 02:08
Dr Gurubasavaraju
http://www.cfd-online.com/Forums/cfx...tml#post580052
Old   November 1, 2019, 14:17
Rubel Ahammed
Rubel Ahammed is on a distinguished road
Dear Sir, Could you please share your mesh detail with me. I am in negative volume error problem.
Rubel Ahammed is offline   Reply With Quote
Old   November 2, 2019, 05:52
It's an FAQ: https://www.cfd-online.com/Wiki/Ansy..._went_wrong.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   November 4, 2019, 02:37
Dr Gurubasavaraju
Mesh size dependent on the geometry of the model. I have used the mesh sensitivity check method to choose the mesh size. Also, try to reduce the time step size.
Movement of piston in a cylinder with fluent? Whitworth ANSYS 5 March 4, 2015 00:50
Piston Simulation helloworld922 Autodesk Simulation CFD 1 September 9, 2012 23:54
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
