LES smagorinsky and SST turbulence
Old   January 9, 2015, 17:22
Default LES smagorinsky and SST turbulence
Siddharth Kulkarni
drsidd10 is on a distinguished road
What differences do we get when simulating a tidal turbine blade geometry using SST (steady state) and LES-Smagorinsky (transient)?
The current problem has been simulated for 2.5m/s inlet velocity, what difference would I get if I were to simulate the same problem for 1.5m/s or even 3m/s inlet velocity for both the analyses?
drsidd10 is offline   Reply With Quote
Old   January 10, 2015, 05:59
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
If you simulate with RANS(+ SST Turbulence model), the set of equations your solving is (because of the high instationary behavior of turbulence) time average . This is done by saperate the velocity in an average and a fluctuating part. u = u_ave + u_fluc
To close the set of equations some modeling approaches are required( Turbulence models like SST).
Thats why you will get a time average solution of the velocity field in your simulation when simulating with RANS.
The LES simulates is not time average, it solves the big turbulance scales directly, while modeling the small ones.
https://www.youtube.com/watch?v=eP_eytKCCFY
Before starting to simulate with LES keep in mind that you will need a finer mesh and a small timestep, based on the turbulence timescale. A rule of thumb for les is that it takes the solver around 100 times longer than with rans. What works best for your simulation depends on what you are interessting in.
Chris_321 is offline   Reply With Quote
k-omega SST SAS High Wavenumber Damping Limiter PonchO OpenFOAM Programming & Development 5 March 21, 2016 13:01
LES required y+ zoozoozoo Main CFD Forum 6 June 12, 2010 08:25
Tutorials for incompressible flow and different turbulence models Sandu69 OpenFOAM 2 April 20, 2010 13:17
