Simulating a Supersonic Diffuser
Old   December 24, 2014, 02:33
Post Simulating a Supersonic Diffuser
Hossein Noorsalehi
noorsalehi is on a distinguished road
Hi All,
I have tried to simulate an inviscid supersonic diffuser in CFX. The inlet boundary conditions are: mach number=3 , Total Pressure is 70000 pa & Total Temperature=300 K. I expect to have a normal shock in the throat or in the beginning of the diverging zone of the diffuser. Therefore the outlet flow regime must be subsonic.
In order to simulate an inviscid flow regime, the viscosity of the Air Ideal Gas is put to 1E-15 pa.s , the flow regime is laminar and the wall condition is free slip.
I have tested various back pressures at the outlet, but the normal shock has brought back to the converging zone and its position is not stable, so the solution will not be converged.
Is CFX a reliable software to simulate such internal regimes? If so, would you please help me solving this problem?
noorsalehi is offline   Reply With Quote
Old   December 25, 2014, 04:43
Yes, CFX should be able to model this.
Have you checked your boundary conditions are correct? Have you done a mesh sensitivity check? Also convergence criteria, time step size (if relevant) and boundary proximity?
This FAQ has more comments: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   November 23, 2022, 14:32
samane
samane_81 is on a distinguished road
Hi Noorsalehi,
could you solve your problem?
Why didn't you use a pressure inlet?
samane_81 is offline   Reply With Quote
invicid, normal shock, supersonic diffuser
[How to obtain supersonic flow inside a supersonic wind tunnel ?] yx213 Siemens 1 September 17, 2014 14:52
Need help defining a momentum source for a diffuser inlet serezhkin CFX 1 April 2, 2013 13:20
Supersonic Inlet for a Compressible Flow in a Nozzle Daco FLUENT 8 November 8, 2012 04:34
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 19:01
Simulating a Supersonic Diffuser-Need Help Dileep Main CFD Forum 1 April 18, 2002 07:25
