Remeshing with INTEGRATED Workbench
Old   December 21, 2014, 08:49
Default Remeshing with INTEGRATED Workbench
Marco
bertozzi_marco is on a distinguished road
Hallo everybody
I have read and tested the two possibility of remeshing you can find
in EDR tutorials.
The first use ICEM meshing system.
The second use Workbench script.
There are limitation for the two method: the first transfer new geometry via coupling monitor parameters with ICEM parametrer
The second use a workbench script to uptdate geometry and a stand alone CFX for results.
If you whant to elaborate complex geometry WITH optimization utility avaliable with workbench there is no possibility to implement remeshing.
Because ICEM hasn't the deep parameter integration you have with DESING MODELLER,
Viceversa
Using workbench script you should exit workbench and you can use only CFX without optimization capability of workbench.
The QUESTION:
Anybody knows if there is the possibility tu run a workbench script via external command WITHOUT exiting workbench ?????????????????
Regards
Marco
bertozzi_marco is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
Remeshing in CFX using workbench meshing. adeban CFX 25 March 29, 2021 06:46
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Workbench remeshing for cfx ghoroobeaakhar CFX 2 January 17, 2015 04:52
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD Chander CFX 3 November 27, 2011 17:24
