December 18, 2014, 13:14 |
Problem running Solution in CFX
Hi, I'm new in Ansys and when I was trying to run Solution for the second time I had this error message:
'GuiOperation Initiate Update from SM Gui' threw exception during Invoke: Exception has been thrown by the target of an invocation And the details: System.InvalidOperationException: Update of the Solution component in CFX did not mark container as updated (final state is Modified). at Ansys.ProjectSchematic.Update.UpdateImpl.throwOrPu blishError(UpdateTask task, String message) at Ansys.ProjectSchematic.Update.UpdateImpl.checkStat eAfterUpdate(UpdateTask task) at Ansys.ProjectSchematic.Update.UpdateImpl.updateCom ponentAndDependencies(UpdateTask task, Boolean& didSomething) at Ansys.ProjectSchematic.Update.UpdateImpl.checkAndU pdateComponent(UpdateTask task, Boolean& didSomething) at Ansys.ProjectSchematic.Update.UpdateImpl.doOutstan dingTasks(IEnumerable`1 tasks, Boolean& didSomething) --- System.InvalidOperationException: Update of the Solution component in CFX failed: Update of the Solution component in CFX did not mark container as updated (final state is Modified). at Ansys.ProjectSchematic.Update.UpdateImpl.doOutstan dingTasks(IEnumerable`1 tasks, Boolean& didSomething) at Ansys.ProjectSchematic.Update.UpdateImpl.<UpdateCo mponents>d__0.MoveNext() at Ansys.ProjectSchematic.Commands.UpdateComponentCom mand.<Execute>d__0.MoveNext() at Ansys.Core.Commands.Concurrency.SuspendableCommand WorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions) --- Ansys.Core.Commands.CommandFailedException: Update of the Solution component in CFX failed: Update of the Solution component in CFX did not mark container as updated (final state is Modified). CommandName: UpdateComponent(Component="/Schematic/Component:Solution", Force=True) at Ansys.Core.Commands.CommandAsyncResult.WaitForSusp endOrComplete(Int32 milliSecondsTimeout, Boolean exitContext) at Ansys.CFX.CFXCore.Commands.UpdateFromSolverManager Gui.Invoke(GuiOperationContext context, GuiOperationArgs args) --- System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. at System.RuntimeMethodHandle._InvokeMethodFast(Objec t target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData, GuiOperationArgs args) at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction) Does anybody know what may have caused this? Or how to solve? I appreciate every help. |
September 23, 2019, 06:44 |
update Failed
Naseer
I am having the same issue. I am running a simulation on a vertical axis wind turbine (very typical simulation) and i keep getting this error for most of my design points. it does work if i go back and update them until it works. the error i get is: "Update failed for the Solution component in CFX. Update of the Solution component in CFX did not mark container as updated (final state is Modified)." A very big waste of time. i don't know what this error means and this thread is the only one i could find that has this issue. |
cfx, error |
Problem with pimpleDyMFoam: Initialise steady state solution | Lancester | OpenFOAM Running, Solving & CFD | 2 | September 29, 2015 10:49 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 20:05 |
CFX Casting problem: Can it be done all in one? | jfasl | CFX | 1 | September 14, 2010 04:14 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
Symmetric problem - Asymmetric prediction | Mark | Main CFD Forum | 14 | January 29, 2001 14:21 |
