Rigid Bodies (Immersed Solids) Boundary Interaction & FSI |
November 23, 2015, 06:40 |
#41 | |
muhamed
Rep Power: 13 |
With the second point, I just want to say that I used only the mass moment of inertia about the rotational axis, which is Izz and I neglected the mass moments of inertia of the other directions, which are Ixx, Iyy, Ixy, Iyz and Ixz. Shall I use the three mass moments of inertia, Ixx, Iyy and Izz? I guess the problem is being with the mass moments because I refined the mesh and the solution is going well. |
November 25, 2015, 04:19 |
#42 |
muhamed
Rep Power: 13 |
I hope anyone can help me with my questions...
November 25, 2015, 07:22 |
#43 |
Rep Power: 144 |
If the wheel you model does not have an external torque applied (ie just inertia) then the torque is zero and there is no power. You need an external torque to generate power.
If the wheel only rotates about one axis then the other moments of inertia are not important. |
November 27, 2015, 04:43 |
#44 | |
muhamed
Rep Power: 13 |
November 27, 2015, 04:47 |
#45 |
Rep Power: 144 |
I do not understand your question. Do you mean you will run the simulation with a defined rotation speed? In that case moments of inertia do not matter. But in this configuration the device will produce (or absorb) an external torque and therefore produce (or absorb) power.
November 27, 2015, 07:17 |
#46 | |
muhamed
Rep Power: 13 |
November 27, 2015, 07:41 |
#47 |
Rep Power: 144 |
You need to look at the system.
The rotor is the power source. It will produce a power versus rotational speed curve. Note that the power at the free wheeling speed will be zero as no net torque is generated. Then the device being powered as a power versus rotational speed curve. Where those two curves intersect is where the device will run at steady state (rotor torque equals device torque). So think of your rotor as one half of a system, and you need to establish the performance curve. You then match it to the performance curve of the device and you cna understand the system operating point. |
November 30, 2015, 06:14 |
#48 | |
muhamed
Rep Power: 13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Rigid Body State Variables in Solid Immersed Simulation | Hamidreza | CFX | 1 | October 19, 2009 07:14 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
