how to make analysis from the result in fluid flow (CFX) ansys workbench 14 |
December 18, 2014, 10:14 |
boy of straits
Rep Power: 12 |
hai. im newbie here. somebody please help me. i was create some design from this cfx in ansys workbench 14. that is water flow in pipe through the propeller. i get trouble to collect the data from the result because it is to complicated. there are so mane values there. i want to get the measurement of water flow rate,velocity, pressure and etc. but the result that produce not in the list. why should i do? what is velocoty u,v,w? what's mean by the graph of 4 colour? that is red,green,yellow and blue? can the data will convert into excel? i need to make analysis from this result. i need to pass my final year project. plis help me.
December 18, 2014, 11:42 |
Rep Power: 13 |
Maybe you should look at your notes from class or look for a tutorial for CFD-Post on-line. They are out there in form of videos and pdfs. Then if you don't understand sth, you should ask your supervisor. There is nothing like a face to face explanation.
And if there is still sth you don't know check this post for forum rules: http://www.cfd-online.com/Forums/cfx...ease-read.html and ask a proper question, that people will understand. Good luck with your project. |
December 18, 2014, 19:56 |
boy of straits
Rep Power: 12 |
tq. but can i know how to attach the image? im newbie here and try to learn. sorry.
December 18, 2014, 20:25 |
Rep Power: 13 |
Yes you can know that and you should. Every icon on the reply board is explained as to what it does, both in quick reply and post reply.
Put some work from your side before expecting someone else to help you. |
Flat plate analysis in cfx | hamed.majeed | CFX | 14 | February 4, 2015 08:07 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 23:43 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
