Hydrodynamic force acting on the oscillating plate
Old   December 16, 2014, 05:31
Default Hydrodynamic force acting on the oscillating plate
Srinivasa Reddy
srireddyn is on a distinguished road
I want to carryout a simulation of oscillating plate (1-DOF) in still water and compute the hydrodynamic force acting on the plate. See the attached figure for problem definition.
I tried to model it as a FSI(2way) problem with Transient Structural module and CFX. I defined a revolute joint and defined oscillatory joint motion. But CFX throws an error ( ANSYS failed to communicate mesh displacement). But simulation is working when I fix the bottom face (no rev. joint in this case)of the plate and apply a bending force to oscillate the plate.
I can't figure out what is the exact problem and how to rectify it.
please help!
srireddyn is offline   Reply With Quote
Old   December 17, 2014, 20:11
Krzychu (Chris) is on a distinguished road
Hi Srinivasa,
is the ANSYS simulation alone converging? The solid domain problem seems to me to be unsolvable by itself. Check the ANSYS out file for error and convergence info.
Also for the rigid case you probably don't need to use the FSI. You could use probably use a moving boundary with prescribed motion. That is if you are interested more in the fluid domain than in the solid.
Cheers
Krzuchu
Krzychu (Chris) is offline   Reply With Quote
Old   December 18, 2014, 01:43
Srinivasa Reddy
Originally Posted by Krzychu (Chris) View Post
Hi Srinivasa,
Cheers
Krzuchu
hi Krzuchu,
Thanks for your replying.
The Ansys simulation(Transient Structural) alone is converging. I have checked this several times.
As you said, for rigid body case we can use moving boundary but when the displacements are large we need to consider the remeshing region to avoid fatal errors due to Negative Cell Volumes.
As far as I know, there are two methods for remeshing. 1. using ICEM mesh replay file 2. User defined.
ICEM replay method can only accommodate translation of the boundary and can't be used for general motion. (see pdf Document: Ansys CFX Reference Guide).
I have no idea about user-defined. In this case we responsible for Data extraction(to modify the Geometry), Geometry modification, remeshing and then supply it to CFX to pre-process and solve.
I am simultaneously trying in Ansys Fluent with Dynamic mesh. In this case I have to write UDF (user defined function) to specify the motion. I succeeded in simulating a 2D model in which boundary is translating and remeshing is done automatically with specified settings under the Dynamic Mesh options.
please share if any other ideas are there.
your valuable suggestions are very much required for my guidance.
Old   December 18, 2014, 01:52
Default Ansys Fluent Dynamic mesh
Srinivasa Reddy
please see the attached pictures of Ansys Dynamic remeshing.
Hydrodynamic force? arun7328 STAR-CCM+ 24 July 25, 2020 05:04
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 05:50
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 08:56
