December 9, 2014, 12:16 |
Newton's Cooling
Nurzhan
Rep Power: 12 |
Hello!
I am trying to simulate Newton's cooling process. Background: I made an experiment where the temperature of a board's surface was monitored over time. Using the experimental data and applying Newton's equation of cooling I determined the heat transfer coefficient of the board. To do so, I fitted Newton's equation to the experimental data. Currently, I would like to simulate the cooling process of the board using the obtained heat transfer coefficient. Problem: Although I fitted the Newton's cooling equation into the experimental results quite accurately, my simulation does not match the experimental results in the same way as the fitted equation? Newton's cooling equations was solved as: T=Ta+C exp(-h A t / V / rho / Cp) where Ta - outside temperature, C - the coefficient of integration, h - heat transfer coefficient, t - the time, A - the are of the boards surface, V - the board's volume, rho - density, and Cp is heat capacity. Thank you in advance. Nurzhan |
December 9, 2014, 17:29 |
Rep Power: 144 |
Please post an image of what you are modelling, and include an image showing the boundary conditions. Also post an image of your mesh and your CCL.
December 9, 2014, 18:06 |
Nurzhan
Rep Power: 12 |
Hi Glenn.
Thanks for your reply. Here all supporting images and CCL code https://www.dropbox.com/s/qdpxhkzzhh...Block.msh?dl=0 https://www.dropbox.com/s/zfo794iihb...ation.ccl?dl=0 https://www.dropbox.com/s/6brz5hfeob...0view.png?dl=0 https://www.dropbox.com/s/nqrs7cyrc7...sides.png?dl=0 https://www.dropbox.com/s/53wx6i8bsw...0loss.png?dl=0 LIBRARY: MATERIAL: Wood Material Description = Wood Material Group = User Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1040.79 [kg m^-3] Molar Mass = 1.0 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 3527.76 [J kg^-1 K^-1] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.504 [W m^-1 K^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 330 [s] END TIME STEPS: Option = Timesteps Timesteps = 0.5 [s] END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Solid Location = B16 BOUNDARY: Heat loss Boundary Type = WALL Location = F20.16 BOUNDARY CONDITIONS: HEAT TRANSFER: Heat Transfer Coefficient = 74.65 [W m^-2 K^-1] Option = Heat Transfer Coefficient Outside Temperature = 18 [C] END END END BOUNDARY: Insulated Boundary Type = WALL Location = Back,Bottom,Left,Right,Top BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END SOLID DEFINITION: Solid 1 Material = Wood Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = None END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: TEMPERATURE: Option = Automatic with Value Temperature = 60.2 [C] END END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 30 END END END SOLVER CONTROL: ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 10 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 14.5 Results Version = 14.5 END SIMULATION CONTROL: EXECUTION CONTROL: EXECUTABLE SELECTION: Double Precision = Off END INTERPOLATOR STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END END PARALLEL HOST LIBRARY: HOST DEFINITION: chen005 Host Architecture String = winnt-amd64 Installation Root = C:\Apps\ANSYS Inc\v%v\CFX END END PARTITIONER STEP CONTROL: Multidomain Option = Independent Partitioning Runtime Priority = Standard EXECUTABLE SELECTION: Use Large Problem Partitioner = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic END END RUN DEFINITION: Run Mode = Full Solver Input File = Fluid Flow CFX_001.res END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 1 Start Method = Serial END END END END[IMG] Many thanks. Nurzhan |
December 9, 2014, 18:26 |
Nurzhan
Rep Power: 12 |
In addition, I would like to ask how to remove heat conduction term from the governing equation using GUI?
December 10, 2014, 00:22 |
Rep Power: 144 |
Have you done all the normal sensitivity checks? In other words:
* Is you mesh fine enough? * Are you converging tight enough? * Is you time step small enough? This is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
December 10, 2014, 02:14 |
Nurzhan
Rep Power: 12 |
Hi Glenn.
Please correct me, if I am wrong. Since, I used Newton's law of cooling, which basically describes the surface cooling, then to simulate this process, the heat equation at the last node must be desctized. In order to simulate it correctly, the governing equation at the surface of the block is described as follows: Because I am only interested in the surface temperature and not in the conduction within the body, then using FVM - implicit scheme: , where , , (as mentioned earlier only the surface temperature is objective), , and will be reduced to . Based on this, the precision of my result will predominantly dependence on the time step rather on the mesh spacing, won't it? I would appreciate if you could advise me how to add the source terms Sp and Su or just one of them? Cheers, Nurzhan |
December 10, 2014, 05:59 |
#7 | |
Rep Power: 144 |
Why not just use the convective boundary condition built into CFX then you don't need any source terms?
Your equations appear to assume that T is constant at all locations in the body. CFX does not work this way, if needs to model conduction and thermal mass in the body to get it right. But if the thermal conductivity is high then the temperature gradient due to conduction will be small. |
December 10, 2014, 17:52 |
Nurzhan
Rep Power: 12 |
Hi Glenn,
The equation written previously shows the discretisation of the last finite volume within my domain. I do agree that there is conduction within the body as the heat leaving the system. However, the heat flux out of the body is controlled by the boundary condition, where the higher the heat transfer coefficient and the lower the ambient temperature, then the higher is the heat loss. Nonetheless, this is what I want to do: During my experiment, I measured the temperature decrease of the block's surface. The the obtained experimental temperature drop can be explained by Newton's law of cooling, which does not take into account any heat conduction inside the body This equation was fit to the experimental data end h value was obtained. Assume, I do not know the thermal conductivity of that material (in my case I know it roughly and used it in ANSYS as the software does not allow me to do transient measurement without specified heat conduction), how then I can simulate this cooling process using ANSYS? How would you do it then? Ideally, using the obtained heat transfer coefficient in ANSYS, then the result must be the same as the Newton's equation. Best regards and many thanks for brainstorming my ideas. Nurzhan |
December 11, 2014, 00:39 |
#9 |
Rep Power: 144 |
I am glad to try to help straighten your brainstorm into a nice laminar flow
Newton's Law of cooling as you have written it assumes that the body can be taken as a control volume where a single temperature value represents the whole body. In other words there is no temperature variation in the body and the body can be represented as a single control volume. CFX does not work this way, you have to discretise your body into a mesh. So if you want to compare your equation to CFX then you are going to have to account for this. I recommend you use a very high thermal conductivity as this will minimise the thermal gradients inside the body. But as long as the thermal conductivity is high enough then the results should match Newton's Law of cooling very accurately. |
December 11, 2014, 01:04 |
#10 |
Nurzhan
Rep Power: 12 |
Hi Glenn,
I was planning to tell you that I finally got what I want, when I saw your post. As you said, I increased thermal conductivity 1000 W/m/K and it worked very well for me. Thanks Glenn. As always you helped me a lot. |
About Cooling channel | alefem | FLOW-3D | 1 | May 28, 2010 12:15 |
Regenerative cooling nozzle. | Brian | Fidelity CFD | 3 | September 1, 2005 09:53 |
Newton's cooling BC | Mohsen | Main CFD Forum | 4 | August 23, 2004 13:11 |
Regenerative cooling nozzle. | Brian | Main CFD Forum | 0 | November 10, 2003 02:11 |
Passive cooling system for batch reactor | Darek | Main CFD Forum | 0 | September 30, 2003 06:06 |
