Temperature dependend fluid properties / buoyancy
Old   December 8, 2014, 15:51
Default Temperature dependend fluid properties / buoyancy
m0h
m0h is on a distinguished road
Hello Community,
I have one more question. I am trying to simulate the properties of oil.
My model should use buoyancy effects. The dynamic viskosity, and the density are temperature dependent. My question is the density:
I did this for an oil with the following expression:
myroh = 883[kg m^-3]/(1+(T-288.15[K])*0.0007 [K^-1])
The density changes with the thermal expansion factor of 0.0007.
Question: Is it neccessary to enter the thermal expansivity factor in CFX at the material properties (Buoyancy Properties), because I already considered it at the density.
If the density would change automatically with the temperature, from my point of view it would be neccessary to have an field density and to give the information at which temperature the fluid has this certain density.
Thank you in advance,
m0h
m0h is offline   Reply With Quote
Old   December 8, 2014, 16:13
Opaque will become famous soon enough
It would be a good exercise to read the ANSYS CFX Solver Theory Guide section about Buoyancy. From the description of the Full Buoyancy and Boussinesq models, you will see when is the thermal expansion coefficient needed, and when it is not.
The values needed can be summarized as
  1. Full Buoyancy: Reference Density
  2. Boussinesq: Reference Temperature and Thermal Expansivity for the material selected
Hope the above helps,
Opaque is offline   Reply With Quote
Old   December 9, 2014, 05:43
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
If you use your own density function, the Boussinesq option is not available and the density difference option is. If you use density difference, it doesn't use the thermal expansion factor in the material properties.
JuPa is offline   Reply With Quote
Old   December 12, 2014, 06:54
hichem
hichemsoft CFX is on a distinguished road
you mean that you want to simulate a mixed convection, if this you want, you to check -g (acceleration of earth), and you inject to modele
good luck
hichemsoft CFX is offline   Reply With Quote
Old   December 14, 2014, 14:09
m0h
Hello all, thank you very much for the hints. i tried to find bousinessq, but as you said its only available if no temperature function is entered. thank you very much!
m0h
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 04:53
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
how to create a temperature dependant fluid Amy CFX 4 October 18, 2009 20:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
