Discontinuous contour at interface
Like Tree1Likes
Old   December 4, 2014, 09:19
Opaque will become famous soon enough
There is nothing wrong with mesh inflation at interfaces. In fact, the use of mesh inflation is always a good thing if by any chance the flow comes at a steep angle crossing the interface with large gradients across the interface.
Generally, mesh inflation is a technique to minimize numerical errors in areas where steep gradients exists normal to the surface. If you are certain the flow comes at a reasonable angle at the interface, and the gradients are gradual across it, you do not need inflation.
Opaque is offline   Reply With Quote
Old   December 4, 2014, 10:33
davide basso
rolloblues is on a distinguished road
I perfectly agree with you in the general consideration...for this very case though, my personal approach would be with prism layers wrapped around the walls (crossing the interface).
Considered the position of the interface I'd probably spend some time trying to have conformal meshes across the interface (1:1 interface as called in CFX )
rolloblues is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
