Mass flow rate boundary condition with negative values
Old   November 25, 2014, 22:34
Question Mass flow rate boundary condition with negative values
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear all,
I am modelling flow in a pipe. My inlet boundary condition is mass flow rate which is initially positive and toward the mid flow cycle becomes negative and eventually becomes positive toward the end of flow cycle.
If I set the mass flow rate as the inlet boundary condition, will the flow enter the flow domain when the mass flow is negative? How is it possible to set a negative mass flow rate as inlet boundary condition in CFX-Pre?
Thanks,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   November 26, 2014, 01:24
Have you tried it? Give it a go and see what happens.
I suspect an outflow mass flow boundary will fail as you need to define additional flow parameters (eg temperature, turbulence etc) when flow enters a domain and you cannot set this on an outlet.
But it might work for an inlet.
Old   November 26, 2014, 01:30
Ashkan Javadzadegan
Actually the model is running now.
If CFX gives error, will switching the boundary condition to "opening" help?
If not, is there any other method to consider the negative mass flow rate in CFX. The negative mass flow is very common case in arteries ...
Old   November 26, 2014, 06:21
If you know the flow direction is going to reverse then yes, I would recommend using an opening.
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
Corrected (Referred) Mass Flow Rate Boundary Condition ermuir CFX 1 November 20, 2012 18:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
