November 25, 2014, 07:29 |
Solver manager error : incomplete line found
Rep Power: 12 |
Hallo, when I display the ongoing run in solver manager, I get the following error:
incomplete line found at end of history file read. It looks like the monitor is not able to read all the steps of the run in progress. Anybody can suggest me how to bypass this problem? |
December 2, 2014, 03:13 |
Daniel
You can update by going to File - Monitor Run in Progress, and select the folder where you are running.
December 12, 2014, 12:22 |
Rep Power: 12 |
It doesn't work. In any case, if the step number goes over 2000 the error comes out
December 12, 2014, 15:07 |
Rep Power: 33 |
Are you starting the run for the first time ? or are you continuing from a previous run ? For the latter, check your settings on how to proceed with the initial values file information such as Use Mesh From, Continue History From and alike.
solver manager error |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 22:24 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
