CFX uses different turbulence models in different computational domains
Old   November 23, 2014, 00:35
Default CFX uses different turbulence models in different computational domains
dhxlxz is on a distinguished road
Hi, everyone, i have a question about using different turbulence models in different computational domains, can anyone give some suggestions about how to setup it ?
dhxlxz is offline   Reply With Quote
Old   November 23, 2014, 18:08
I would strongly recommend against this if the domains are fluidically connected.
The only time I would consider this is if you had two fluid domains separated by a solid domain (so heat transfer is the link between the fluid domains). Try the "allow constant domain physics" expert parameter to see if you can do it - search the forum on details of how to apply this.
Old   November 23, 2014, 23:10
Thumbs up Thanks for your reply
Hi, ghorrocks,
i would sincerely appreciate your kind reply. ^_^
Use of two different turbulence models at the same simulation agustinvo OpenFOAM Running, Solving & CFD 4 January 28, 2022 03:25
the differences between turbulence models agungwp FLUENT 6 July 1, 2018 04:02
in k-epsilon wall function approach high Re turbulence models: question of velocity romant OpenFOAM Programming & Development 6 May 26, 2016 10:14
variety of turbulence models in cfx? hamidciv CFX 5 January 4, 2016 03:41
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
