Velocity profile assessment
Old   November 19, 2014, 12:11
Default Velocity profile assessment
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
Dear Friends,
I am performing LES of T-junction mixing using CFX. My inlet conditions are
Hot inlet: T - 421 K, v - 0.16 m/s
Cold inlet: T - 298 K, v - 0.084 m/s
bulk velocity in mixing region is 0.18 m/s. I am analyzing velocity distribution downstream of T-junction in the mixing region. Attached along with this thread is the velocity profile in the vertical direction (z axis) at 6 diameters (6D, with D - 71.8 mm) downstream of T-junction. Velocity is higher near the upper region where no mixing occurs (marked by red contours) than in the lower region (where mixing occurs). The reason for this behavior (in my opinion) is the low density of hot fluid which does not mix due to low velocity of cold fluid (0.084 m/s) coming from branch pipe. Also, Richardson number in mixing region is calculated to be Ri = 1.7, indicating buoyancy effects.
Could you guys help me in understanding the reason for higher velocity near upper region of pipe ? Thank you for your help in advance.
Regards,
Karthick
selvam2487 is offline   Reply With Quote
Old   November 19, 2014, 17:28
An image of what you are modelling would be useful.
Old   November 21, 2014, 14:57
Default T junction geometry
Karthik
Dear Glenn,
I have attached the pictures of my T-junction model. Hope this gives you the required information that you were looking for. Thanks for your help.
Regards,
Karthick
Old   November 23, 2014, 18:01
I bet the side inlet flow is corkscrewing around the main flow. This will reduce bulk mixing and allow these flows to stay separate for longer.
Put streamlines on the side inlet and I bet they corkscrew around.
Old   November 23, 2014, 18:34
Karthik
Dear Glenn,
This LES is based on experiments performed at my institute and I am performing numerical validation for a particular test case.
1. Yes, the flow is not completely mixed through out the computational domain due to low velocity of branch fluid (Reynolds number - 3670) whereas the hot fluid in main pipe has relatively higher velocity (Reynolds number - 38400) along with buoyancy effects (Richardson number - 2.93 in the mixing region).
2. Also there is turbulent penetration of hot fluid into branch pipe and vice versa and is confirmed by experimental measurements.
3. So, there is incomplete mixing of fluids and velocity in the upper region (where no fluid mixing occurs) is higher than in mixing region. So am I correct in thinking that the low density of hot fluid near upper region along with mixing of fluids (which introduces fluid from branch pipe into main pipe) results in higher velocity near the upper region of pipe than in mixing region?
I have attached velocity and temperature streamlines for your reference.
Thank you.
Regards,
Karthick
Old   November 23, 2014, 18:40
Your images show the flow is not corkscrewing around, it is the hot and cold fluids separating and oscillating slightly from an equilibrium position.
Just as the incomplete mixing can lead to a thermal gradient it can lead to a velocity gradient as well.
Note that I do not know what fluid model you are using for this, if the fluid is compressible then there will be density effects as well.
Old   November 24, 2014, 01:18
Karthik
Hello Glenn,
It is incompressible fluid model and variation of physical properties of water with temperature is taken into account using IAPWS libraray
Regards,
Karthick
les, mixing region, velocity profile
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 02:52
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 13:14
