November 14, 2014, 07:18 |
Monitor Heat Flux in CFD-Pre
Claudio Torregrosa
Rep Power: 13 |
I am running conjugate heat transfer transient CFX calculation of an air cooling system where the heat load to cool down is applied only during a short amount of time. I want to monitor the heat flux in the outlet of the cooling system. So I can obtain afterwards a curve of total Power/heat removed through the outlet as a function of time, and check how efficiently I am removing the heat. The problem is that, when I define the expression I want to monitor in CFX-Pre, which would be something that: areaInt(Heat Flux)@Outlet I got a cell error, as it seems Heat Flux is not a CFX-Pre variable. If you look at it in the variables tag of CFX-Pre you will not find it. This is very surprising, as Heat Flux it does appear as a variable in CFD-post. I tried using "Wall Heat Flux" which appears in CFX-Pre, but when I check in CFD-post "Heat Flux" and "Wall Heat Flux" do not give the same values at all for the case of an outlet. Do you know any reason why this is happening? Propose any solution? Thanks in advance Claudio Torregrosa CERN EN-STI-TCD Bld 865/R-D16 F-01631 CERN Cedex France Mobile: +41 76 7337 983 Office: +41 22 76 62663 |
November 14, 2014, 11:01 |
Rep Power: 33 |
Unfortunately, you are correct. "Heat Flux" is a CFD-Post only variable at the moment. Wall Heat Flux is a similar variable available from CFX-Pre->CFX-Solver and CFD-Post as well.
The main differences between Wall Heat Flux and Heat Flux are boundary edge effects when averaging from the faces values (integration points) to the vertices of the faces (a vertex is shared by several faces). If what you need is the energy flow through an inlet/outlet, you can always write the pieces that account for it. For a non-radiation case, the energy flow can be computed as Thermal Energy --> massFlowInt(Static Enthalpy)@Inlet Total Energy --> massFlowInt(Total Enthalpy)@Inlet Such calculation should be fairly close to areaInt(Heat Flux)@Inlet. Hope the above helps |
November 18, 2014, 07:44 |
monito heat flux on lines
carla menale
Rep Power: 12 |
Hello! I have a problem to monitor the heat flux on line constructed with the option Surface->line/rake
It's always zero, but the temperature is changing. I'm using: monitor->Surface->total Surface heat flux |
November 19, 2014, 10:52 |
Erik
Rep Power: 23 |
Heat Flux is a wall boundary variable, you can't just place a line in space or at in inlet/outlet and get a variable for heat flux.
November 20, 2014, 05:17 |
carla menale
Rep Power: 12 |
I'm not sure this is the problem. If I make a line in correspondence of a wall created with gambit, there is the heat flux.
I plotted the wall made with gambit and the line made in corrispondence of this wall and the flux is the same. The problem is with other lines made inside the domain. |
November 20, 2014, 12:45 |
Rep Power: 33 |
Perhaps not worded properly, but "boundary only variables" only contain values at boundaries; therefore, their values is not defined in the interior. Any derived locator could contain section where those variables are not defined.
In your case, if the lines crossed a boundary, you will see the value to be undefined everywhere except at the crossing point. In ANSYS CFX, any variable prefixed by Wall XXX is a boundary only quantity. Examples include Heat Flux, Wall Shear, Wall Irradiation, etc. Hope the above helps, |
cfx-pre, expression, heat flux, monitor |
Evaluate Heat Flux through plane in CFD Post | hugo17 | CFX | 4 | May 13, 2013 21:51 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
