How to simulate a fan without the geometry of fan?
Old   November 10, 2014, 03:59
Default How to simulate a fan without the geometry of fan?
Sangwoo Kim
swtbkim is on a distinguished road
Hi all.
I'm simulating a fan inside a pipe.
But it is sort of cumbersome to simulate a fan directly.
And I'm interested in a flow outside a pipe, not inside.
So I'd like not to use frozen rotor or something, but to simulate only air-sending function of a fan.
How can I do it?
I thought that momentum source is enough at first,
but I think it can not reflect the effect of pressure change of a fan because momentum source is defined as force per unit volume acting on the fluid.
How about using momentum source and porous media together?
Velocity and pressure decrease passing through porous media, and only velocity will increase passing through momentum source zone.
Any idea will be highly appreciated.
Thanks in advance.
Best regards
swtbkim is offline   Reply With Quote
Old   November 10, 2014, 04:02
Sangwoo Kim
I forgot attaching an image.
Best regards
Old   November 10, 2014, 04:15
Sangwoo Kim
Oh one more thing lol
I heard that there is a function of "Fan modeler" or something.. I don't know exact name.
This maybe what I want: don't make fan geometry, but just designate specific zone as a fan.
Is there anyone who heard about this function?
Best regards
Old   November 10, 2014, 05:13
The fan model might be a Fluent thing. You have to define it yourself in CFX.
There are two main options to implement this:
1) Use a momentum source (and no porous region is required)
2) Use an outlet/inlet to specify the flow.
1 is better if you want the air to recirculate. 2 is better if you know parameters definable by the boundary conditions, such as the inlet and outlet pressures or flow rates.
Old   November 10, 2014, 05:56
Sangwoo Kim
Thank you, Glenn.
Your replies are always really helpful.
I think 2) is suitable.
Is this figure what you suggested?
Far field will be treated as an opening
Best regards
Old   November 10, 2014, 17:04
Yes, that is what I was talking about.
Some minor points:
* There is no need to have such a long duct into and out of the inlet and outlet. A short duct is all that is required. For the inlet probably no duct at all is acceptable (so just flush with the end of the pipe).
* The mesh in the duct can also be coarser. You are not modelling this flow accurately so do not waste mesh elements in it. You need enough to get a basic flow profile, but don't worry about boundary layers or fine details like that.
Old   November 11, 2014, 01:10
Sangwoo Kim
Thank you for your considerable advice.
1. The location of inlet should be over there for next calculation.
2. Thank you. It's a good idea.
And, can you explain about details of boundary conditions at inlet and outlet?
I tried as follows:
inlet : velocity inlet, 3m/s
outlet : pressure outlet, -100Pa
opening : opening, 0Pa
Is this nice?
Best regards
Old   November 11, 2014, 01:18
Do you mean what is the meaning of inlet, outlet and opening; or do you mean the boundary conditions you have implemented in your model?
If it is your model please post an image of your whole domain showing where these boundary conditions are located.
methodology to simulate fan performance analysis ayothicfd Main CFD Forum 4 July 3, 2013 21:56
How to simulate on geometry with curvature seboxx OpenFOAM 1 January 18, 2012 06:43
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
How can I simulate a fan in a cavity Elvia Martinez CFX 1 September 7, 2005 10:49
Simulate geometry in different parts Ralf Schmidt FLUENT 0 July 29, 2005 11:08
