Constant properties water with variable density as a function of temperature
Old   October 30, 2014, 18:10
Default Constant properties water with variable density as a function of temperature
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
In the material properties for water is it possible to use constant properties for everything except density?
I want density to be a function of temperature and pressure.
I've read that the Redlich Kwong real gas model may be able to do this. However if I turn it on, is it as difficult to converge with as full IAPWS (where every property is a function of pressure and temperature)?
Thank you
JuPa is offline   Reply With Quote
Old   October 30, 2014, 20:30
Ali Madayen
AliMadayen is on a distinguished road
Hi. Sorry but I can't get the problem right.
Isn't it possible by a simple expression? or there is something that makes it more complicated?
AliMadayen is offline   Reply With Quote
Old   October 31, 2014, 05:16
Yes, you can use constant properties except for density. What density equation of state do you want to apply?
Old   October 31, 2014, 05:47
JuPa's Avatar
Mr CFD
I have an Eulerian-Eulerian free surface setup. I am modelling water liquid and water vapour, separated by a free surface.
I would like to apply variable density for the water liquid equation of state.
So far I am modelling variable density in the water vapour phase as an ideal gas assumption.
I've just stumbled across a fourth order polynomial expression of density as a function of temperature for the water liquid phase, which I may implement. This is the equation:
Density [kg/m^3] = (-2.98043*10^-8*T^4)+(4.93093*10^-5*T^3)+(-3.25853*10^-2*T^2)+(9.18937*T)+82.2757
Obviously to use the above expression you would need to call upon a dimensionless temperature (just divided T by 1 [K]) to give the correct units of density [kg/m^3].
Bar this approach, are there any others which would give me variable density for water liquid, but constant properties for everything else?
Old   November 1, 2014, 05:43
Rather than generate a dimensionless temperature use the correct units in your function. For instance:
Density = (-2.98043*10^-8 [kg m^-3 K^-4]*T^4)+(4.93093*10^-5[kg m^-3 K^-3]*T^3)+(-3.25853*10^-2[kg m^-3 K^-2]*T^2)+(9.18937[kg m^-3 K]*T)+82.2757 [kg/m^3]
If you wanted variable density but constant everything else and you know this equation is the density versus temperature function then I would just use this, rather than trying to use the more sophisticated models.
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Warning 097- AB Siemens 6 November 15, 2004 05:41
