October 30, 2014, 11:17 |
calculating the enthalpy with/in CFD-Post
Rep Power: 13 |
I need your help for calculating the enthalpy with/in CFD-Post from an CFX .res file. Boundaries: CO2 - real-gas Reference pressure 3700000 Pa Now I want to calculate the enthalpy with the expression: massFlowAveAbs(Static Enthalpy)@ massFlowAveAbs(Total Enthalpy in Stn Frame)@ And the isentropic enthalpie HTSOut with: HTIn+(cpRef*tTotalIn*((pTotalOut/pTotalIn)^((gamma-1)/gamma)-1) The calculated enthalpies doesn’t make sense, because HTSOut is bigger than HTOut. I think it is a problem with the reference enthalpie. Can somebody help me to understand the “problem”? Thank you and greetings |
cfd-post, enthalpie, reference |
Problem in CFD -post | pratikvn | ANSYS | 4 | March 21, 2018 03:56 |
calculating output parameter in cfd post | markus67 | CFX | 3 | August 26, 2015 10:28 |
View results at a contact region in CFD post | AGP | FLUENT | 0 | June 10, 2014 12:11 |
Negative value for static enthalpy calculation in CFD Post | brajh11 | CFX | 8 | April 30, 2014 03:53 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
