Jumpy Wall Shear Behavior
Old   October 27, 2014, 09:58
Default Jumpy Wall Shear Behavior
Leifheit is on a distinguished road
when I took a look at some of my results today I noticed a rather strange wall shear behavior. A screenshot is attached.
Has anyone else encountered such 'spiky' wall shear behavior?
Velocity and other stuff is fine.
Leif
Leifheit is offline   Reply With Quote
Old   October 27, 2014, 17:23
I do not know what you are graphing and I do not know what spike you are concerned about. Please explain what you are doing.
Old   October 29, 2014, 08:25
Sorry about that. I am graphing the wall shear in streamwise direction over the span of an airfoil.
The spikes I am talking about are those in the graph - as far as I know it should be a smooth curve.
The case has reached convergence and other stuff, for example the velocity field around the airfoil, look just fine.
Turbulence Model used was SST Gamma Theta for Transition.
Old   October 29, 2014, 09:43
I also made some more pictures ... maybe those help understanding the problem ... I am still kinda new to cfd stuff so I might give too little / wrong information - if thats the case please tell me what you need!
Old   October 29, 2014, 18:44
Which spike don't you like?
Don't forget that you will have very sharp pressure gradients near the leading and trailing edges. Also at a separation or a laminar to turbulent transition you will also get big pressure gradients. So sharp pressure gradients can be real.
Old   October 30, 2014, 06:03
Hey,
thanks for the effort you put in this!
Its not a single spike I dont like - it is the „jumpy behavior“ ... sorry dont know how to put this in better words ... the graphs should be more smooth I think.
I found a graph of the drag coefficient over the span of an airfoil at multiple RE numbers - the behavior of the graphs should be the same as wall shear in x direction.
Apparently the calculations were also made with CFX so it should be possible to get results that are of similar quality.
The magnitude of my results is just fine (in terms of drag and lift coefficient etc) - it just would be nice to have good looking results since I want to show the jump from laminar to turbulent behavior.
Old   October 30, 2014, 06:29
This is sounding like a FAQ now: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Pay particular attention to mesh resolution. Jumpy curves like what you see are commonly caused by too coarse meshes.
Old   October 30, 2014, 09:16
Unfortunately I do no think this is the case ... I did a mesh study on this considering the parameters
Y+
Streamwise grid refinement
Expansion Rate of Cells
with no change in the behavior.
I also tried doing multiple transition iterations - thats when I ran out of ideas
Just looked into it again ... the velocity gradient (perpendicular to airfoil surface) shows the same behaviour ... which makes sense since
... cant really figure out why though ... I will try to run the simulation with a different turbulence model and see what happens.
Old   October 30, 2014, 17:53
Another issue to look into is how well the curvature is resolved. The solid modelling may have facetted the face.
Old   October 31, 2014, 06:38
Sorry dont really understand your advice....
how well curvature is resolved = how many samples cfxpost takes ?
Old   November 1, 2014, 05:38
No. The solid modelling package (DesignModeller in particular) approximates curved surfaces with facets. For most applications the approximation is good and no problems occur. But for simulations which rely on very accurate definition of curvature (airfoil modelling is a good example) this does cause problems sometimes.
If you zoom into your geometry on designmodeller you will see it is facetted. There is a setting in DM to set the geometry tolerance to reduce this.
What does “Mean Wall Shear Stress” mean? dfytanid FLUENT 4 November 6, 2016 21:19
how to resolve high gradients of wall shear? Agad15 FLUENT 0 June 10, 2014 00:59
Wall shear stress distributions en51nm STAR-CD 2 January 28, 2010 05:42
Problems with wall shear stress. xiexiehezuo FLUENT 1 September 22, 2009 13:26
Macro to set Wall Shear Stress Satish FLUENT 4 November 26, 2003 15:46
