RFR Solver error
Old   October 22, 2014, 14:16
Default RFR Solver error
Rolando Figueiredo
RPFigueiredo is on a distinguished road
Hello again!
I know that this is perhaps the most common error message in this forum, but I can't figure it out: I get the floating point overflow error everytime I set a rotating frame of reference.
The meshes are OK, since they work when stationary. The timestep is set to 1/speed, and the interfaces are set to frozen rotor (only the impeller is in a RFR).
There must be something I am missing in the set up. Is someone more experience able to pick something up? I mean, the solver barely starts before signaling the error!
Thanks in advance!
RPFigueiredo is offline   Reply With Quote
Old   October 22, 2014, 18:47
Yes, that is right That is why we wrote this FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Old   October 22, 2014, 20:08
Rolando Figueiredo
Yea, but the FAQ does not say a word about why it happens when rotation is involved.
The time step is correct, the mesh has no elements of quality below 0.5, and it still happens.
My question is about the link between numerical stability and the RFR. When I run the thing with a stationary impeller, all is fine.
Old   October 22, 2014, 20:21
How can you be sure of this when it is not converging? Have you tried a smaller time step as the FAQ suggests? This is the most common fix for this problem.
Old   October 22, 2014, 20:28
Rolando Figueiredo
1/(10*speed) didn't work. The reason I posted the issue here is because the problem isn't the convergence.
As soon as the solver starts the error appears, before iteration 1. That's what's bugging me. I've even tried a simpler model, just a spinning tube - just because it's rotating, the solver barely starts.
Very unsettling!
Old   October 23, 2014, 06:37
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
Does the job run in serial and not parallel?
JuPa is offline   Reply With Quote
Old   October 23, 2014, 08:11
RFR runs are normally quite reliable. I rarely have troubles with them. RFR does not significantly increase the numerical instabilities in most cases.
If you run a simple model and that does not work either then I suspect you are setting up RFR wrong. Have you done the tutorial examples on RFR? Can you post some details of the simple RFR model you did?
Old   October 23, 2014, 08:45
Rolando Figueiredo
Yes, I've done tutorials, I've modeled rotor-stator interaction too, and I haven't encoutered this issue.
All the boundaries are walls, except for the top inlet, the anular outlet and the two interfaces, both set to General COnnection/Frozen Rotor with pitch change of 1. I cannot set inlet/outlet as counter rotating (and really that's why I am not modeling only the impeller, but the whole system) - perhaps leave them as openings and check if the rotation works its magic?
And RicochetJ, the job doesn't run in either!
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
