October 20, 2014, 05:03 |
Errors
Mansoor Saleem
Rep Power: 12 |
Hello
I have a some problems. like Whenever I Stop the running simulation, I get an error like some file is missing and CFX is not able to save the results and all the results are lost. Sometimes when I try to open CFX Pre, I get message that some file is missing and CFX Pre shows no data, it appears just a simple setup.(without any domain, boundary condition) Even after "Clearing generated data" the file takes more than 30 minuts to Save If I want to copy the whole simulation folder, it is in GBs and takes long time to copy Thnk you so much for response and reply |
October 20, 2014, 06:23 |
Rep Power: 144 |
This commonly happens when you run out of disk space. Is your simulation data files big? Do you have enough disk space?
Do small simulations run correctly? |
October 20, 2014, 06:28 |
Mansoor Saleem
Rep Power: 12 |
Thanks Ghorrocks
I am connected to server which have no space problem and my Simulation results are justifiable. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
