Mahdi Mazloom
Rep Power: 12 ![]() |
I want to model transient cross-wise two-dimensional flow over a fixed cylinder. Should I consider a turbulence model for the fluid for Re up to 20000? Based on attached figure from "Blevins, Flow Induced Vibration, 1990" vortex street transforms from laminar to fully turbulent for 150<Re<300000. But boundary layer stay laminar in this range of Re. If so which turbulence model should I use? Meanwhile I'v tried no turbulence modelling and the results seem good regarding Strouhal number. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
I would try the SST model in that range first, and if that seems to be giving you too much dissipation int he boundary layer then move to the gamma-theta turbulence transition model.
cfx, flow regime, turbulence, vortex shedding |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 02:29 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
