Roland Rakos
Rep Power: 17 ![]() |
I would like calculate a screw compressor and I need to have the forces acting at the bodies. As far as I know, the immersed solid method can be applied to move and rotate the solids but it is not applicable to evaluate the acting forces, moments. What kind of method could you suggest to solve this problem? (The mesh deforming method would be too complacated, I think.) Thank your help and suugestions; Roland |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Immersed solid is by far the easiest way to do this type of a simulation. Have a look at the compressor tutorial for how to set it up.
Roland Rakos
OK, but can I evaluate all forces acting on bodies exactly? There are forces from fluid flow and forces from the mechanical interaction (between bodies). These forces result the summa forces at bearings which I should have. Can I calculate all of these forces with immersed solids method?
Bodies cannot interact with immersed solids.
If the bodies both have fluid forces and mechanical interaction forces then this is a MUCH more difficult simulation. So much more difficult that I would recommend you consider whether it is worth it. Can the forces be separated? Then you can do an immersed solid simulation to get the fluid forces and a FEA simulation to get the mechanical forces. |
Cemal
Rep Power: 0 ![]() |
Hey Ronald,
Can you handle it this problem? I have same problem now. |
Rotational axis for hydrodynamic screw | SirLankyIII | FLOW-3D | 0 | June 2, 2014 03:29 |
Simulation of a twin screw pump | Maralady | CFD Freelancers | 1 | July 25, 2013 02:26 |
FLUENT & SCREW COMPRESSORS | Suresh | FLUENT | 2 | September 30, 2004 00:19 |
fluent and screw compressors | Suresh | FLUENT | 2 | September 28, 2004 21:25 |
create screw in CFX built | methee | CFX | 1 | July 8, 2003 22:28 |
