Viscoelastic Model
Old   October 1, 2014, 19:25
Default Viscoelastic Model
Josiah Lund
lund8619 is on a distinguished road
I am working on a simulation that I would like to use viscoelastic properties for. I have simulation data from the model before applying the viscoelastic properties and also for after. After applying, the model is failing due to a negative element. The part that is confusing me is that the negative element is being seen long before my pressure wave reaches the viscoelastic material. I have attached images of the two pressure plots, which show a pressure reading that to me, is unexplained.
The only difference between the two simulation is the addition of a Prony Shear Relaxation property.
Values for the table are as follows:
Temperature = 27 [C]
Relative Moduli(i) = 5.5556
Relaxation Time(i) = 2.5e-5 [s]
These values were chosen based on the information found on page 6 of the following document
http://ansys.net/ansys/papers/nonlin...ng_viscoel.pdf
I have also linked this page to a previous issue that is still unsolved with this model. I would like to resolve both issues, but achieving a successful viscoelastic simulation is my priority
http://www.cfd-online.com/Forums/cfx...tructural.html
lund8619 is offline   Reply With Quote
Old   October 5, 2014, 08:32
Have you checked your convergence when it crashes? I bet the solver is going bezerk.
Old   October 9, 2014, 13:33
Josiah Lund
Glenn,
I do not know how to check the convergence when the simulation crashes. I tried running two separate simulations using low and high convergence criteria and the results are different from one another, but surprisingly, the one with worse convergence criteria ran longer. I have included images of these two runs.
Is there any reason as to why the higher convergence model would crash earlier?
Old   October 9, 2014, 19:07
This sounds like your model is highly numerically unstable so anything can happen. I would not read too much into how quickly things crash other than you need to improve numerical stability.
You can do that by:
* Smaller time steps
* Double precision numerics
* Better mesh quality (this one is the usual problem, you can always do a better mesh)
* better initial condition
negative elements, negative volume, negative volume element, viscoelastic
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 14:32
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
