October 30, 2014, 05:28 |
#21 |
Robert Bischof
Rep Power: 12 |
I found a paper from Ansys with Information about transient simulation in CFX. There by I have realised the meaning of some values.
To take some experience I will start a transient Simulation and if there are any question after the run I will report another post. Unfortunately the file size of the paper exceed the maximum file size, so I can't attache for other user. |
October 30, 2014, 18:04 |
#22 | |
Robert Bischof
Rep Power: 12 |
I have set up my first transient simulation. For Time Duration I set 10s (but now I think the value is to high to reach).
There by for me arise three further question: 1. Whats the difference between "Analyse Type" --> "Timestep Adaption" --> "Target Max (Min) Loops" and "Solver Control" --> "Convergence Control" --> "Max (Min) Coeff Loops. I set Target Max Loops = 5; Target Min Loops = 3 and for Min Coeff Loops (=1) and Max Coeff Loops (=10) I don't change the default values. Is this right or did I misunderstood the post of ghorocks: Quote:
3. What will I see in the Transient Result Files. Thank you for your help! Greets |
October 30, 2014, 18:07 |
#23 |
Rep Power: 144 |
1. Those values look OK
2. Note that as the time step size will vary the time spacing of the results will vary. But you appear to only be interested in the final result so you might not need transient results files at all. 3. snapshots of the flow at that time step. |
October 30, 2014, 18:14 |
#24 |
Robert Bischof
Rep Power: 12 |
thank you for the fast reply.
For my opinion in the result file there are no transient Information and with the transient files that all "build" my transient simulation. But now I think thats wrong. I will take a look on my simualtion the next days, I think there will be more question |
November 3, 2014, 07:29 |
#25 |
Robert Bischof
Rep Power: 12 |
The trend of my transient simulation looks very good (for me).
I attache the progress of the residuals and imbalances, pressure at the interesting Monitorpoints and Reynoldsnumber at the interesting region. With this results: Can I say, that the shedding region have no effect on the pressure and Reynoldsnumber in the interesting region ? It's look like a steady state solution from a transient run, is this right ? I'm just surprised about the fast convergence ?! |
November 3, 2014, 07:48 |
#26 |
Rep Power: 144 |
Sure looks steady state to me. So it looks like you needed a transient run to get to a steady state solution. This happens sometimes.
November 3, 2014, 08:42 |
#27 |
Robert Bischof
Rep Power: 12 |
Now I'm happy, after a long time I have finally a solution.
Thank you for you endurance, ghorrocks. It was a great help! |
November 14, 2014, 13:09 |
#28 |
Robert Bischof
Rep Power: 12 |
Once again I have a question about how to interpret my transient run.
My tutor said, the fluctuations of the MassFlow (it's MassFlow at inlet) from the steady state run (see picture) have also to occur in the transient run. I don't understood this, because I have no transient boundary. Can someone explain me, what I really (have to) see when I look at the transient run? And when I look on the timestep: The adaptive timestep method decrease the timestep from initial timestep (4e-4) to the minimum timestep (1e-10). I thought the adaptive timestep method finds the rigth timestep to resolve transient flow changes ? Now I'm a little bit confused. |
#29 |
Robert Bischof
Rep Power: 12 |
Here are also the RMS values for the transient run.
November 15, 2014, 00:47 |
#30 |
Rep Power: 144 |
What settings did you use for the adaptive time stepping?
November 15, 2014, 20:36 |
#31 |
Robert Bischof
Rep Power: 12 |
I made screenshots of the settings I have used
November 16, 2014, 05:05 |
#32 |
Rep Power: 144 |
Of course your simulation went bezerk - you have 1e-12 as a residuals convergence criterion. You should replace this with something more sensible, 1e-4 is a good starting point for a transient simulation.
November 16, 2014, 06:16 |
#33 |
Robert Bischof
Rep Power: 12 |
I choose the value, because I want to stop the run by my self, equal to steady-state run.
But I will start my simulation with a value of 1e-4 once more. |
November 16, 2014, 06:22 |
#34 |
Rep Power: 144 |
The whole idea of a transient run is to advance it through time. When you choose 1e-12 residual tolerance that means the adaptive time stepping will just reduce the time steps to nothing and you do not advance in time - which defeats the purpose of the transient simulation you are trying to do.
November 20, 2014, 05:20 |
#35 |
Robert Bischof
Rep Power: 12 |
The timestep size (6.6127e-5) is unchanged since 250 timesteps. Can I assume, that a good timestep size is found ?
Is it recommend to start another run with a fix timestep size found by the adaptive Method ? Or should I change the residual convergence criteria ? You will see, that all flow values begin to oscillate. I want to research the frequencies and the different values at different timesteps. |
November 25, 2014, 10:21 |
#36 |
Robert Bischof
Rep Power: 12 |
Does no one has an answer ? My simulation is advanced very well.
What can I do for further investigation ? Should I run with fix timestep size ? Or shoud I increase residual tolerance ? |
November 25, 2014, 18:31 |
#37 |
Rep Power: 144 |
Your results show there is clearly a strong transient effect happening.
But what happens next is entirely up to you. Do you want to investigate the periodic cycle? Or the startup transient? Or are you just interested in the overall averaged behaviour? Each of these will require a different approach. |
November 26, 2014, 06:02 |
#38 |
Robert Bischof
Rep Power: 12 |
Initially I'm interested in the behaviour of the periodic cycle (frequences and maybe pressure allocation on different times) and on the overall averaged behaviour.
So I will execute the items one by another, but I don't really know how to start for both. For a start I would disregard the transient startup. |
CFX vs FLUENT for particle tracking simulation | iman | ANSYS | 2 | August 31, 2012 21:34 |
nucleate boiling simulation in CFX | Anil | CFX | 3 | August 25, 2010 15:18 |
CFX steady simulation | gharek | CFX | 1 | April 7, 2010 19:41 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 09:44 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 14:54 |
