September 23, 2014, 04:30 |
Creating Expression in CFX
shikha
Rep Power: 13 |
Goodafternoon Friends,
I am very new to this field and trying some simple tutorials of CFX. I am trying to create expression from the available expression tab but shows an error as shown below: WARNING Syntax error detected in the expression assigned to 'Speed'. Successfully read 3 characters: 60 then error detected at: [mph] Details - Unrecognised or invalid units. I named speed as expression and enter its unit under 3rd bracket ([mph]) which results in above mentioned error. Can anyone tell me where am I going wrong or what is the correct procedure. |
September 23, 2014, 06:57 |
Rep Power: 144 |
CFX will not recognise "m" for miles - it means metres. It will not recognise "p" for per either, you need to either use power or / to indicate ^-1. I think you are OK with "H" though.
If CFX recognises miles then [mile h^1] should work. Otherwise you are going to have to convert it to something like kilometres and enter it that way. |
September 24, 2014, 00:57 |
shikha
Rep Power: 13 |
Thank you so much for your reply sir!
September 24, 2014, 04:49 |
Missing icons on the CFX toolbar
shikha
Rep Power: 13 |
Hello Sir,
Some of the icons on the toolbar are not shown. Can you suggest me how to drag them to the toolbar (eg. Define Run, Run Solver and monitor icon etc.) |
Suggestion on new dynamic viscosity expression in CFX | TitusOfei | CFX | 25 | June 14, 2018 01:37 |
Molar fraction in CFX Pre expression | Niekjuh | CFX | 4 | July 14, 2016 20:11 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
Error when creating an expression for a drag coefficient | CFD_UJI | CFX | 5 | May 8, 2012 09:43 |
Creating, loop or iteration using expression edito | Jan | CFX | 3 | July 28, 2003 12:01 |
