September 18, 2014, 06:17 |
CEL or Fortran
Rep Power: 13 |
maybe it was already discussed but I didn't found anything. For huge calculations with fields and gradients is it better to use Fortran than the CEL? Which one will work faster? Thanks for reply! Thomas |
September 18, 2014, 06:40 |
Rep Power: 144 |
I almost never use fortran, regardless of the simulation size. CEL does not have much overhead, except if you are using CEL to calculate field variables. But if you are using CEL to calculate field variables you probably want to include it in the result file so you can check it is working as expected - this would apply regardless of whether you are calculating the variable by CEL or fortran, so the overhead is similar in both cases.
September 18, 2014, 06:42 |
Rep Power: 13 |
Ok thanks for the advice. I don't want to use it for the results file but for the calculation of the drag coefficient using the AIAD model by HZDR. http://www.cfd.com.au/cfd_conf09/PDFs/011HOH.pdf
CEL or Fortran Code | hana-90 | CFX | 3 | January 24, 2017 09:56 |
Additional Variables Defined By User FORTRAN CEL | Wheeler | CFX | 2 | August 6, 2013 22:33 |
CEL vs. USER FORTRAN | Zaktatir | CFX | 0 | February 16, 2013 07:29 |
CFX arc-modeling, User Fortran, CEL.... | Bloshchitsyn Vladimir | CFX | 2 | October 15, 2007 10:29 |
CFX arc-modeling, User Fortran, CEL.... | Bloshchitsyn Vladimir | CFX | 0 | October 15, 2007 07:17 |
