CFX temperature initialization
Old   August 26, 2014, 09:42
Default CFX temperature initialization
jp_
jp_ is on a distinguished road
I encountered a weird CFX behaviour today (in transient runs)...
1-I set up a non-temperature dependant analysis (ex Isothermal) and get some preliminary results
2-Make a new config in which I introduce non-isothermal aspects (ex wall temp, etc), use (1) as "Continue from file" and an initialization condition for temperature (automatic with value), run it.
However when you open up results, you notice that it
a-takes fluid velocities & pressures from (1), as expected
b-initializes not at the initialization temperature set in (2) (as you would expect), but at each of the fluid's reference temperature set in (2)...
I did find the expert parameter below, but it seems very vague in what it does. Any clue?
transient initialisation override
Type
Logical
Default Value
f
Description
When set to 't', enables solver default values to be used for initialization in a transient simulation.
Is (b) known behaviour? Why should ref temp take precedence over explicitly specified initialization? Is there a way around?
jp_ is offline   Reply With Quote
Old   August 27, 2014, 00:19
This sounds strange. It might be a bug. Have you reported it to ANSYS?
Old   August 28, 2014, 10:02
jp_
Hi Ghorrocks,
Turns out you can change meshes and do all sorts of stuff, but adding heat transfer to an existing run produces less than ideal results... I'll just have to include heat transfer in the stabilization phase (1)
Cheers!
Old   August 28, 2014, 10:06
That sounds like a useful work-around. But what you describe sounds like a bug so it would be worth while to report it to ANSYS and get it fixed.
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Cfx aborted due to unknown errors AKHILESH S L CFX 2 October 10, 2013 18:16
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
