in user fortran, how to get velocity gradients |
August 23, 2014, 05:22 |
田道贵
in CFX simulation, I use the fortran code to add a model, which needs liquid velocity gradient in radius.
in codes, I use "USER_GETVAR" to get the velocity gradient, Call USER_GETVAR("water.Velocity w.Gradient",CRESLT,pGVel,CZ,DZ,IZ,LZ,RZ) while it does not work and error presents in CFX solver as follows: Details of error:- ---------------- Error detected by routine MAKDIR CDRNAM = VEL-3_FL2 /GRADIENT CRESLT = ILEG Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR Anybody encounter this issue? Thank you for you kindness! |
August 23, 2014, 18:48 |
Rep Power: 33 |
It seems the user_getvar utility has problems with gradient of vector components.
Try getting the gradient for velocity and work out the Velocity w.Gradient values out of it. It will be good to check the documentation for how the array is organized for gradient of vectors. If recall correctly, it should be (3 Gradient components, NLOC, 3 variable components) |
August 23, 2014, 20:41 |
田道贵
Though I addressed this problem by using the variable "water.Velocity.Gradient", I still thank you very much.
user fortran, velocity gradients |
Comparison between C/C++ and Fortran? | rick | Main CFD Forum | 45 | September 6, 2011 00:52 |
user routine, user funcion, or fortran compile effect on the memroy? | princeps11 | CFX | 1 | May 13, 2009 18:37 |
User Fortran and Particle momentum source | alvio | CFX | 0 | July 30, 2008 22:52 |
CFX arc-modeling, User Fortran, CEL.... | Bloshchitsyn Vladimir | CFX | 0 | October 15, 2007 06:39 |
CFX11.0 cannot find dll in User Fortran | brunoc | CFX | 0 | April 4, 2007 10:42 |
