Conjugate heat transfer mesh requirements (picture attached)
Old   August 21, 2014, 08:51
Default Conjugate heat transfer mesh requirements (picture attached)
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
In conjugate heat transfer problems we're solving the energy equation in a solid domain, which may be in contact with a fluid domain where we solve all of the conservation equations.
In the solid part, since all we're doing is simulating the diffusion of heat through the solid I assume the the mesh requirements for the solid part does not have to be amazing (but still adhere to orthogonality and skewness requirements). Is this a valid assumption?
Which leads me to my main question:
At the solid - fluid interface (see attached) can I have a sudden jump in cell size from the solid (grey) to the fluid (blue) domains?
Please note I have not finished the final mesh - I will have more cells in the solid (grey) domain to capture the temperature gradients.
Thank you.
JuPa is offline   Reply With Quote
Old   August 21, 2014, 19:28
Steady state heat flow is just diffusion, so is linear. In that case a very coarse mesh can resolve this OK. You might be OK with just a single element thick - but I would check on an analytical case first before committing to it.
But for transient heat transfer, the transient bit can put additional thermal gradients into the material. Whether this is important to you or not is dependent on how fast the transients are and how accurately you need to resolve them.
Old   August 21, 2014, 19:33
Opaque will become famous soon enough
Keep in mind that diffusion solution is linear only if there is no curvature of the isotherms. For example, steady state one dimensional radial diffusion has a logarithmic profile between inner and outer radius. The isotherms may be packed near the boundaries depending of the radii ratio in that case.
Opaque is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Conjugate heat transfer kiteguru CFX 2 January 9, 2012 16:57
Conjugate Heat Transfer boathead STAR-CCM+ 1 April 15, 2011 10:13
