August 20, 2014, 10:33 |
areaAve(Pressure) with back flow
Robert
Rep Power: 13 |
Hey,
i have a problem regarding the right pressure measurement of areaAve. I have a pipeflow arrangement like shown in attachement 1. The diameter suddenly decreases. Now i am trying to get the pressure distribution along the pipe. I create a plane and move it along the pipe, taking the area averaged pressure at every step. The result is shown in attachement 2. How can i get rid of this downswing? My guess is, that it is probably because there is a backflow around the core flow like shown in attachement 1. any suggestions are appreciated.
Regards Robert |
August 20, 2014, 19:43 |
Rep Power: 144 |
This is real - the flow is accelerating in the vena contractor and has a locally reduced pressure.
If you want to get rid of this then use a rounded pipe entry. Make sure the radius is large enough that it does not separate. Or even better use a more optimal shape like an elliptical profile. |
August 21, 2014, 07:37 |
Robert
Rep Power: 13 |
Thank you for your answer.
In fact wasn't looking for a solution to prevent the separation, but for a way to get the "right" pressure distribution. I obviously did not make it clear enough. But thank you anyway, because it reminded me of a person named Daniel Bernoulli, who said that there is not only the static pressure, which i get from areaAve(Pressure), but also the dynamic pressure.
Regards Robert |
August 21, 2014, 12:05 |
Edmund Singer P.E.
Rep Power: 21 |
massFLowAve(Total Pressure)?
Are you trying to compare this to something? |
Back flow in axial comperssor | eslamnagy | CFX | 4 | May 27, 2013 07:42 |
how to correct back flow in fluent? | aminepoxnet | FLUENT | 1 | March 20, 2013 16:15 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 3, 1999 00:18 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 08:33 |
