Add material to a domain
Old   August 19, 2014, 20:25
Lightbulb Add material to a domain
Lissette
Lissette_acn is on a distinguished road
Hello!
I am trying to model a porous material. And when I try to add the material I created, in the soil domain, It doesn't appear on the list. I have created this material within different lists such as "the user list" which doesn't appear in the options to add and within other lists... obtaining the same result
Lissette_acn is offline   Reply With Quote
Old   August 20, 2014, 08:42
Opaque will become famous soon enough
You may need to explain the steps you are going through for someone to help you.
For example, have you tried just copying an existing material with a different name and see if you can add it. If you are able to, you can then start changing one attribute of the material at a time.
Opaque is offline   Reply With Quote
Old   August 21, 2014, 02:26
Lissette
It seems that adding a copy and then modifying it works
Assigning Solid Material Type to a Nozzle in Nitrogen Fluid Surrounding Domain faizan CFX 10 February 17, 2014 19:43
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
