Thermal Radiation, Interface Type: Fluid-Fluid
Old   August 19, 2014, 18:02
Default Thermal Radiation, Interface Type: Fluid-Fluid
jhon fredy hincapie
hinca is on a distinguished road
Hi all
The main fluid domain is splited into several domains where there are Fluid-Fluid interfaces between them. I have set a thermal radiation model to the fluid domain (Monte Carlo, Gray).
I have no idea about how to model the thermal radiation on the fluid-fluid interface in the corresponding CFX tab. I have set up the domain interface tab as follows but I dont know which parameter to set on thermal radiation,
Basic Settings -> Interface Type: Fluid Fluid
Interface Side 1: Domain #1
Interface Side 2: Domain #2
Interface Models: General Connection
Additional Interface Models -> Mass And Momentum: No Slip Wall
Heat Transfer: Conservative Interface Flux
Interface Model: Thin Material / Steel / 0.001[m]
Termal Radiation: ?????????
In the "Additional Interface Models" tab I don't know what to put in "Heat Transfer" and "Thermal Radiation" for temperatures convergence.
if you have documentation, tutorials or know how this problem can be resolved please let me know.
thank you very much in advance.
hinca is offline   Reply With Quote
Old   August 20, 2014, 08:39
Opaque will become famous soon enough
You are creating a thin wall to separate two regions of fluid.
The interface models available for thermal radiation are
- The thin wall is transparent to radiation w/o any attenuation, i.e. Conservative Interface Flux
- The thin wall is opaque to radiation; therefore, you must set the emissivity and diffuse fraction on either side of the wall.
Hope the above helps,
Opaque is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Inlet patch problems martyn88 OpenFOAM Running, Solving & CFD 6 April 21, 2017 19:34
SimpleFoam - instable simulation Specialist OpenFOAM Running, Solving & CFD 17 August 12, 2014 05:52
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
